Hi!
You need to replace your capacitor. You will find it located behind the control panel. To purchase a replacement see this page:
www.GeneratorGuru.com
If you need more advice we can get you in contact with one of our Generator Engineers to guide you. We do not charge for this service and are happy to assist you throughout the repair.
Kind regards
The Generator Guru Team
Specialist Portable Generator Engineers & Parts Worldwide
Test regulator
Needs to verify voltage and power quality with proper meters. Adjust or repair as necessary.
SOURCE: power supply light has blinking green light
If the power box is bad, The computer will not come on. if you only get a green light, you would need to start with replaceing the power box, if you get a new one and the same thing happens, then the mother board is bad too.
SOURCE: Please Help me to unlock in Globe sim card , Philippines
dreyedison,
let ur phone be openlined..a thing that called in philippines so that u can use any other network or sim card u want..just go to any cellphone shop then tell them..they automatically know what ur toking bout..
SOURCE: I have a power supply problem with my Drink-O-Matic product.
You can email the service department about it. I had a similar problem. A new power supply is $25 including shipping. If yours is still under warranty I believe it is free.
[email protected]
SOURCE: I plugged the printer into 220 volts inlet ,burned power supply
Cheaper to replace the machine than buy a power supply - unless you find a parts machine somewhere.
SOURCE: No power to coach when generator runs but power
Do you have automatic switch over in your system, or is there a receptacle where power cord stores, that you need to plug power cord into, for power from generator?
