Can you send me a video on it?
SOURCE: saturn crankshaft sensor
Right above the started. It can be removed from under the car withour taking the starer out. 5 minute job, one bolt
SOURCE: where is 2003 saturn ion thermostat?
FACEING the ENGINE It is At TOP RIGHT SIDE Close to Master Cylinder takes About 1 hour to Replace Have Fun its a EASY One
Please Dont forget to RATE ME Thank You
Remove the feed pipe
Installation Procedure
Install the thermostat and retaining sleeve with the dimple placed into the housing slotImportant: Lubricate the O-ring with soapy water or coolant before installing the O-ring in the water pump.
SOURCE: 2005 saturn ion
I am not a mechanic and have had no problems with my 2005 Ion-2 but at msn/autos I see that these can exhibit a starting problem because of the ignition switch which they recommend replacing. The part is around $40 & the labor is 1 hr.
SOURCE: my saturn ion stalls when making left hand turn
Sounds like a fuel issue to me. Maybe the fuel is sloshing to the right of the tank and causing air to be drawn into the fuel line. Just a guess but something to think about.
SOURCE: How to unlock radio in 2005 saturn ion
It may be complicated, depending which radio you have. UC1 or US9, US8. The owners manual should have all the info you need. You do have the radio code, right? If not...you will need to visit the dealer. If you have the code, the radio must be on for 1 hour and then it will unlock when it reads - - - - , and you can put the code in. Its not your girlfriends fault. ; )
