S
SHASHI KUMAR Posted on Dec 17, 2018
Hi,I have a jamo s210 subwoofer,it's got current,light on but no sound.what may the cause? input all connected well
5 Related Answers
Anonymous
  • 56 Answers
  • Posted on Mar 18, 2008
SOURCE: I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Anonymous
  • 19 Answers
  • Posted on Apr 03, 2009
SOURCE: sound faliure
If the subwoofer has its own power cord seperate from the rest of the audio system, the internal amplifier could be fried or u have a loose connection inside the box
Anonymous
  • 263 Answers
  • Posted on Aug 04, 2009
SOURCE: How to connect to an subwoofer
You need a subwoofer cable then you attatch the cable from the back of the amp into the sub and power on the subwoofer and amp and hey presto your away.
Anonymous
  • 118 Answers
  • Posted on Nov 04, 2009
SOURCE: cannot get jamo 250 subwoofer to work via marantz
hdmi has digital audio in it. no need for optical from same device.
check menu settings in receiver to activate sub, set crossover point and levels
Anonymous
  • 8546 Answers
  • Posted on Jan 18, 2011
SOURCE: My subwoofer is connected correctly (test mode it
What's the make and model of the subwoofer? It sounds like it's a passive (unpowered) speaker.
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
See page 9
I seriously doubt your test mode worked fine on the subwoofer level adjustmnent.
Get a powered (active) sub.
How do you connect a Jamo sub250 to a Onkyo tx-sr343 av receiver
You simply connect a RCA type line cable from the subs line input to the dedicated socket on the back of the Onkyo.
When you run speaker set up it will set the subwoofer up.
2answers
The fuse of Jamo Sub-200 gets blown off. is there anyone who might know the reason. thanks
try replace the blown fuse with ampere and check the sound if still ok.
some fuse got blown if the load current exceed. maybe high volume can cause the high current.
other cause by short circuit coming from the amplifier.
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
1helpful
Please help! Jamo SUB 300 subwoofer still blows (0.8A) fuses after replacing a faulty thermistor, despite a high ohms reading directly across AC mains terminals on the board. What is causing the fuse to...
hi,
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not working.is it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me out.my receiver is onkyo tx-sr 608
thank you
ron
Sound faliure
2answers
JAMO SUB 650
hi
since it is a powered speaker, probably it just needs a sound signal which you can get from the headphone socket. please double check with someone else.
2answers
Dual Voice-Coil
Jamo 250
hi, there must be this LINE IN socket (ur so called Hole), then on the onkyo, there must be this sub-line out socket, plug one end of the RC socket to the sub out of onkyo , and other to the line in of the sub, its all to do wirth its appropriate inputs and outputs,let me know
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
