SOURCE: Instant Pot electric pressure cooker display a "C6" error code, what could be the problem?
best to start by fliping it over an takin it apart an take a look
Your first
IF condition is “=IF(C6>6000,0.15%*(C6-6000),0)”
Where:
C6>6000 is your logical condition
0.15%*(C6-6000) would be the value if your logical condition
is TRUE, and
0 would be the value if your logical condition is FALSE.
Your 2nd
IF condition is “(IF(C6>30000,0.3%*(C6-30000)))”
Where:
C6>30000 is your logical condition
0.3%*(C6-30000) would be the value if your logical condition
is TRUE, and
? would be the value if your logical condition is FALSE.
You are missing the value if it is FALSE.
Hope this
be of some help/idea. Post back how things turns up or should you need
additional information.
Good luck
and kind regards.
6 - DC Peak Error
• Supplied power is not normal
• Comp Connector (CN-U,V,W) is disconnected or inserted to wrong
position
• Compressor is damaged (coil short) ? replace compressor
• Too much Refrigerant
• Defect in outdoor pcb assembly ? replace pcb assembly
Try turning power off to external unit, usually resets diagnostics and runs OK. If not PCB external unit likely culprit, replace!
