Https://www.google.co.uk/search?q=arris+SB6122+how+to+reset&tbm=isch&ved=2ahUKEwiwtpLcyaffAhXMw-AKHUksDScQ2-cCegQIABAC&oq=arris+SB6122+how+to+reset&gs_l=mobile-gws-wiz-img.3...6615.13075..14102...0.0..0.511.2472.1j8j2j1j0j1......0....1.........30i10.xM36b77_ylc&ei=4PUXXLDGDcyHgwfJ2LS4Ag&prmd=simvn&biw=360&bih=623#imgrc=pMRlyEjHlRAd2M
Click on the link if not leave another question or Google my name for more help
Thanks
Ian
Shut down your router and disconnect all the cables including power cable and press power button of router for 60 seconds and connect all the cable and connect it to the computer and check
SOURCE: Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
SOURCE: itouch wi-fi connection problem
Try this one : http://wiredforgadgets.com/?p=743. It worked for me.
SOURCE: Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
SOURCE: my d-link 2640t wireless router suddenly no Wi-Fi
This one can be one of two things.
If you have a digital multimeter, check the power connection and make sure that it's not to high (eg. 7.5 V DC should read no more than 7.8 V for it to work properly)
Otherwise, just reset the router. I have a feeling it is the first one.
Once it reaches to 130% above of what's rated, it can fry your network adapter in your computer and possibly more damage if it's wired.
SOURCE: Wi Fi button on medion
Hello
What you need to do is to go online,try to download the installation driver for the wifi nd re-install it but if your system has the installation cd you could use
BEST OF LUCK
On your ipod touch
Verify Wi-Fi is enabled and that you are connected to a Wi-Fi network.
Tap Settings > Wi-Fi. If Wi-Fi is off, turn it on by tapping the on/off icon.
Available Wi-Fi networks appears under "Choose a Network..."
Locate and tap the Wi-Fi network you want to join then enter your password
Hi Barry Carver, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
can you confirm the make and model number of the router and the make and model number of the wi fi access device ?
