Washing Machines Logo
Rose Marie Posted on Dec 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washer starts to fill when starting a cycle but stops filling after 10 seconds. Husband went to do a load of laundry and came back and the clothes were still dry.
My Maytag Neptune is one of the original models, about 20 yrs old.
Lollo Pop
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 134 Answers
  • Posted on Dec 17, 2018
Lollo Pop
Expert
Level 2:
Cheetah:
Answers
134
Questions
0
Helped
73769
Points
301
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Jan 28, 2008
SOURCE: brand new kenmore HE2 front load washer - keeps filling
Either your pressure switch is bad, or the air line that connects to the presuure switch has come loose. The pressure switch is located on the right-hand side rear of the washer with the top cover removed. It is a brown colored, disk shaped, device with an electrical connection and an air hose connection. Sometimes this hose comes loose in shipping, or the electrical connection may be loose. Without it, the washer will continue to fill and will NOT shut off. Now...if you just purchased this unit, DO NOT do anything that will void the manufacturer's warranty. It may be an inconvenience, but I would recommend you get the appliance repairman to come in and take a look at it. That way...you won't be held liable if something were to break. This is, however, usually a simple problem and not considered major. I hope this reassures you some. Post back with comments if you have any further questions/concerns.
Anonymous
  • 1073 Answers
  • Posted on May 11, 2008
SOURCE: Washer won't fill with water but will start cycle!
check the water pressure switch
Anonymous
  • 3361 Answers
  • Posted on Mar 12, 2009
SOURCE: Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
tomsat69
tom wright
  • 219 Answers
  • Posted on May 18, 2009
SOURCE: WASHER FILLS AND AGITATES, BUT THEN STOPS, WILL NOT DRAIN OR SPIN
It may be a bad lid switch. Cheak with your meter for continuity.And if you need more info let me know.Also how old is the washer for there are 2 differant styles of lid switch dipending on how old the washer is. hope i helped :)
Anonymous
  • Posted on Nov 15, 2010
SOURCE: Washer starts agitation during water fill up and
I also have a Whirlpool top load Model # WtW57ESVW auto sensing load washer. I have it it almost a year and it has started to do exactly the same as described above. The repairman said today that it needed a "auto load sensing switch" which he has ordered for me.
Note - you can use your washer until the problem is fixed, but you have to make sure you manually stop the spin cycle prior to it just finishing, for that is the time period that the water starts to fill again.
I also noted that my local Lowes store does NOT sell this model anymore - probably too many customer complaints about this exact same problem. As soon as I showed the problem to the repairman this AM, he immediately diagnosed the issue - said that it was a recurring issue with this particular model.
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
1helpful
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
The water pipes have been freezing up for the past two nights, got them thawed out, and started a load of laundry set on cold. Washer started normal, it made a small click noise as allways, and the water...
Have you taken the hose off of the back of the washer and checked to see if you are getting water to that point. Also check the inlet screen on the fill valve to see if it is clean.. You may need to replace the fill valve. There may be a screen in the inlet of the hose at the shut off valves.....So check both ends of the washer hose..... I would check the hoses first before I would replace the fill valve....Hope this helps
2answers
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
Washer won't stop filling up
TAKE BACK OFF LOCATE CLEAR HOSE THAT CONNECTS TO PRESSURE SWITCH REMOVE FROM SWITCH AND BLOW OR USE SMALL BLAST COMPRESSED AIR TO CLEAR IT OF THE CLOG THAT IS LOCATED IN THE CUP TO TUB. POWDER DETERGENTS LIKE TO CREATE A CLOG IN THAT CUP. RUN SMALL HOT WASH CYCLE NO CLOTHES
The rinse cycle does not work, but everything else does
I don't know if the problem is solved but last night we ran the washer without any clothes in it and everything seemed to work fine. My wife was able to run a load of laundry and it seemed to work. I hope it was just too much clothes the first time it stopped or the washer was just acting up. Either way, I had nothing to do with the fix. Sorry I couldn't be any more help. Thank you for the link to assistance plan, it might come in handy in the future.
Thanks again,
Sandro Micocci
2answers
Fisher Paykel will not drain
I had the same problem. After cut the power off for at least 60 seconds and then back on, as the manual suggests, the problem remained. Therefore I started putting the clothes out and bailing the water out. Once the water was down about half way the pump started working. I suspect the sensor was "stuck". I cycled the washer without clothes and it worked fine. Still working after several loads of laundry. The water level sensor will probably need replacing sometime soon.
Top Washing Machines Experts
john h
