My receiver is a Yamaha RX-V581
Resetting/Initializing the receiver to factory settings
Warning: This will erase all settings and return the unit to its original factory settings.
Note: This procedure is done on the front panel of the receiver only.
1.Set the unit to Standby by pressing the Power button.
2.While holding down the Straight button, press the Power button.
3.SP IMP. 8 Ohm Min (Or 6 ohm) will come up on the Front Panel.
4.Press the Right Program Arrow button repeatedly until INIT-CANCEL comes up.
5.Press the Straight Button repeatedly until INIT-ALL comes up.
6.Press the Standby button to turn off the receiver.
7.The next time the receiver is powered on, the factory settings will take effect.
SOURCE: AV-DV75 volume control not working
Hi Deebo check the following website www.dalsani.com www.repairworld.com good luck open the set and you will find the part number printed on the body of the component. NB.but i am in the belief that it IS your IC that is damaged.
SOURCE: yamaha rx-v657 zone 2 volume
Go into zone 2 in menu select the source you want then turn up the volume for zone 2,this should work.
hope this helps.
CABLE CUY.
SOURCE: Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
SOURCE: No volume in Zone 2
Get the original Yamaha remote, go to Set menu, manual setup, speaker setup, and look for "extra speaker." it needs to be set to "zone 2." This is off the top of my head, so it should be pretty accurate. Get used to doing this, though, as this amplifier assignment to zone 2 is prone to resetting itself in those Yamahas.
SOURCE: Yamaha RX- V 663 - unable to change volume on Zone 2
Page 111:
PROBLEM: Zone 2 speaker settings are not available in "SET MENU".
CAUSE: "EXTRA SP ASSIGN" is set to a setting other than "ZONE2".
REMEDY: Set "EXTRA SP ASSIGN" to "ZONE2".
See Page 85
Testimonial: "Hi it certainly pointed me in the right direction. Thank you. A few more steps would have been useful and page number suggestion was not correct p33."
