Sewing Machines Logo
Helen Sutphen Posted on Dec 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Free Motion quilting on a Janome Horizon Memory Craft 9400
I want to free motion quilt with a ruler foot on my Janome Horizon Memory Craft 9400 and cannot figure out the settings. I have lowered the feed dogs, but the presser foot is to tight against the fabric and it will not move.
Giselle
Level 3:
Genius:
  • Master 1,015 Answers
  • Posted on Dec 18, 2018
Giselle
Master
Level 3:
Genius:
Answers
1015
Questions
6
Helped
286183
Points
2407
When I pay for the CDKeys on M8X.com, how can I get it? and how to use it?
5 Related Answers
Anonymous
  • 41 Answers
  • Posted on Jul 31, 2008
SOURCE: fREE MOTION QUILTING
Hi Susan,
You're absolutely correct, you'll need to either drop the feed dogs (lever generally located near the bobbin case or on the outside base of machine) or cover the feed dogs with a plate (many machines have this included).
Then... you'll need to lower the presser foot - when you lower it, it should NOT touch the bed of the machine but sit slightly raised off the fabric surface. As you stitch the presser foot will lower onto the fabric to hold it taught as the needle penetrates.
Oddly enough it's easier to achieve smooth stitches when sewing at a faster speed, but begin by stitching fairly slowly until you get a feel for free-motion stitching. You'll be doing all the guiding and it may feel a bit strange and uncontrolled at first.
Position yourself at your machine so that when your hands on your fabric/bed of machine, your shoulders are relaxed (not all hunched up) and your elbows are slightly higher than the bed of the machine.
You'll want to stitch in a side-to-side or back and forth motion (as opposed to trying to turn the fabric.
Best of luck with this technique. Once you're comfortable with it, you're sure to enjoy the freedom of creating!
Happy sewing,
Kim & Linnette
bargainbox
Hassy
  • 1388 Answers
  • Posted on Mar 28, 2010
SOURCE: I cannot get the feed dogs to come back up on my
Flick the switch to raise the feeddogs then rotate the handwheel one full revolution to re-engage the cam...voila
Anonymous
  • 1116 Answers
  • Posted on May 01, 2010
SOURCE: Free motion quilting
Refer to the accessories and you will find one is a darning plate. If you check the section for darning, there will be more information.
Look on the throat plate and there should be a tiny hole on each side of the feed dogs, this is where the plate snaps into place.
If you do not have the plate, set the stitch length to zero, and then tape an index card over the feed dogs with a hole punched out for the needle.
You may use this method forever, or check with your local Brother dealer for the accessory.
RichSew
Douglas Plant
  • 222 Answers
  • Posted on Jun 03, 2010
SOURCE: Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Sep 01, 2010
SOURCE: I have this White model
to allow the free moving and to do it by hand ..it has a button that will low the feeding dog and practically you will move the fabric by hand..or ..just remove the presser foot from the screw..or if it is possible ..free the screw and lift the foot up to the max..for a larger feeding dimension ..
I have a Janome Horison Memory Craft 8900 SpEd, thread looping on backing side for free motion. DO i NEED Part No. 200-445-007 Janome Bobbin Holder for Free Quilting and Hand-Look Quilt Stitch.
Free motion quilting is a finicky function, much more than most other sewing. Since you are getting loops on the back of the fabric, try increasing the upper thread tension. Tension causes the top and bobbin threads to pull against each other. If the pull is not equal, the threads will be pulled to one side or the other.
If you continue to experience looping under the fabric, it could be that the top thread is not fully seated in the tension disk. Try this:
Remove the top thread completely from the machine.
Be sure to install a brand new sharp needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Retest your machine.
However, if you don't find a fix, $25 for the special bobbin holder is probably a reasonable cost if it takes care of the problem. The reviews seem to be good:
http://www.sewvacdirect.com/janome-bobbin-case-for-free-motion-quilting-fits-models-mc14000-mc6500p-mc6600p-mc11000-mc7700-mc12000-and-more/
https://thequiltshow.com/forum/domestic-sewing-machines/120-janome-mc6600p
"Yesterday I bought a new free motion quilting foot and a bobbinholder (for free motion) for my MC Janome 6600P. I have been quilting all day, and belive you me it is a greate investment!!! :lol: :lol: Its like sewing on butter :lol: :shock:
Free motion Quilting Foot: part no.: 200-442-004 (MC6600P and MC11000)
Bobbin Holder (for free quilting and hand-look quiltstitch): part no.: 200-445-007 (MC 6600P, MC11000 and MC6500)
Bet you would love to have those too if you are doing a lot of free motion! The quiltfoot you can adjust so it works perfectly on your quilt!
:lol: :D :wink: I am sooooo happy!!!!"
https://www.getasquiltingstudio.com/2012/01/free-motion-quilting-tips-ii.html
LOOPS Tension or Speed
Free Motion Quilting Tension Problems
My janome memory craft 6500 is making noise when using quilting mode, what could be the problem?
Not knowing what kind of noise, it would be hard to diagnose. Suggest taking it for service.
Janome Memory Craft 8200QC Horizon. Can you get a stitch regulator? How does it work? Does it help to free motion stitch ?
You should check with a Janome dealer if your machine can use a stitch regulator. Machines that take a stitch regulator need the ability to plug into the machine, which is not available on a lot of machines unless they have the stitch regulator function. A stitch regulator helps some people. It still takes a lot of practice moving the fabric smoothly.
On my BSR, it has an "eye" that measures the distance the fabric moves under the presser foot so it can stitch at the specified distance. The faster the fabric moves, the faster it stitches, but the stitches tend to more uniform in length.
FWIW, I read a summary of the Janome 8200 QC Horizon and there was no mention of a stitch regulator.
http://freemotionquilting.blogspot.com/2011/05/piecing-quilting-on-janome-horizon-7700.html
Can I do stippling on my 400xl
This is free motion quilting. There are a ton of web sites and videos available. You'll need a darning or free motion quilting foot for your machine. Drop the feed dogs. If you are certain you want to do free motion quilting, a Supreme Slider helps you move the fabric.
https://www.amazon.com/Supreme-Slider-Motion-Machine-Quilting/dp/B007XGITA2
Learn How to Free Motion Quilt Stippling
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting for Beginners 10 Tips
Free Motion Quilting Beginner Tutorial 1 of 4
How do I set up my Janome 1600p-qc for free motion quilting?
You will need a darning foot or free motion quilting foot for your machine (these feet are shorter than the regular feet which allows space between the foot and the needle plate to manually manipulate your fabric). Then drop the feed dogs and, if your machine does not have that capability, there should be a cover plate included with your machine that snaps over the feed dogs. Install a brand new needle in your machine, set it for a straight stitch, and test the stitch. Sometimes, the upper tension needs to be loosened a bit so the bobbin thread does not poke through the top of the fabric.
Then...practice, practice, practice...
FWIW, I've found it helpful to use a "Supreme Slider" on the base of my machine. It is slick and allows the fabric to move easily. Special gloves are helpful too because your hand will become dry and begin to slip on the fabric. Using cheap rubber gardening gloves works for some people.
supreme slider Google Search
quilt gloves Google Search
1helpful
Janome 1600P DBX
You need to drop the feed dogs, install a darning or free motion quilting foot (make sure the presser foot is lowered). Because you will not be using the machine to move the fabric, the stitch length selection is of no importance. Make sure the stitch width is set to zero. You should test FMQ on a scrap quilt sandwich of the same makeup of your project, ie quilt fabric with batting sandwiched between. The upper tension should be set so that both threads meet in the middle of the quilt sandwich. Because it is FMQ, some extra adjustment may be needed.
Once the tension is where you want it, you can practice FMQ until you can move it smoothly in conjunction with the machine speed.
Practicing on a white board with erasable markers is a handy way to learn to move smoothly. The most difficult part of free motion quilting is learning to move the fabric smoothly. Do NOT lack for practice as that is the only way to improve. Those people who make it look simple have been doing it for years!
Free Motion Quilting for Beginners Part 1 Video from Sewing with Nancy
Please all deales joname model no 5002 this is part all joname sewing machine work
Are you looking for the free motion quilting foot for a Janome?
Here is a link to pictures on the internet; I find not parts for a Janome 5002, only 5001. You need to contact Janome's Service on the Internet.
janome quilting foot free motion quilting Google Search
Do i have adjust tension when free motion quilting on janome 6125
No but need free motion foot, FMQ is A bit of an art, slow hands and even stitching. Doing a class is a great way to learn as stipple quilting looks great but takes practice.
2answers
Bobbin thread is not being picked up when I free motion quilt
Duh. It was the breaker. Always check the breaker ...especially around Xmas!
I have a Janome 6500 Memory Craft and I'm having problems with the thread tension while free motion quilting. No matter what the setting, the bobbin thread keeps popping up on the quilt top! I've only had...
Check this in your manual. I think when you do free motion you have the feed dogs (toothed things the rise up and pull the fabric under the presser foot) locked down but you still have to have the presser foot lowered. When the presser foot is locked in the up position, the tension on the bobbin thread is released.
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
