Question about Casio Televison & Video
Casio ae1000w battery replaced, but it dies fast.
The charge lasted for about 30 minutes, then the watch went blank again.
SOURCE:
robotek
  • 1512 Answers
SOURCE: Casio GW300 (2608) battery replacement
Hey all. The charge provided by the solar cells on the watch only really extend the life of the battery. The total run time of a battery depends on how the watch is used... backlight requirements etc. The battery will be depleted and need to be replaced.
Here is a site that has good instructions on how to change the battery in your G-Shock watch.
http://forums.watchuseek.com/showthread.php?t=20217
If you want to ensure you still have a the same water resistance rating, I do suggest that you take it to a watch guy to have it replaced for you. They clean switch contacts also and you keep water resistance rating. Good Luck and vote this as a "FixYa". Cheers
regards
Graeme
Posted on Feb 14, 2008
SOURCE: casio 1170 watch was working
You have to ground the battery. Re-open the watch and look at the movement, there should be a "AC" or a "+" Take a pair of tweezers and put one tong on the + side of the battery and the other tong on the "AC" or "+" leave ther for 3-4 seconds.That should do the trick. If not working still, let me know. I will assist you further. Good luck!!
Posted on Sep 10, 2008
SOURCE: charged battery only lasts 30 minutes
Try fully draining the battery and recharging it fully. If that does not work chances are the battery is going bad. How old is the dvd player ? If its still under warranty you might be able to get a replacement.
Posted on Jan 05, 2009
escapement
  • 2338 Answers
SOURCE: Casio 4305 runs 5 minutes slow.
No reason to panic as your watch hands can be advanced to desired time. Her is the link for your watch users manual download:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4305&submit.x=52&submit.y=12
Save it on your PC and follow instructions how to set the time.
Don't forget to rate, please.
Posted on Jan 06, 2009
  • 183 Answers
SOURCE: Changing the battery on My Casio watch module 1848. Two
The contact springs most likely have nothing to do with your screen being black.
The watch will have an "AC" or all clear function that needs to be performed. Check the back lid for AC or reset instructions. If there are no instructions there then you will have to visit a watch repairman/technician to have this procedure performed as it involves touching the AC pad on the circuit board to the back of the battery already installed. The circuit board is easily damaged if not performed properly.
Posted on Sep 17, 2009
Why does my Wave Ceptor WVA-105H work sporadically after getting wet?
Try a new battery. When water got in there it may have shorted the battery and drained it. It may work for a short time and then die. Also put the watch on you car dashboard in the sun to bake it instead of the oven unless you have an electric oven. For electric oven use a thermometer to get temp of 140 F then turn the oven off and put the watch in for an hour.
Aug 16, 2014 | Casio Watches
Casio pathfinder battery operated watch keeps blanking out display?
Your watch is solar powered, so I think it isn't charged lately. At a low charge, the watch goes into saving mode by switching off the display (while keeping the time, date, etc.). To charge the watch leave it in a brightly lit spot for a day or two. That should be enough to make the watch function as normal again.
For more information, you can download the manual of your watch here (direct download link):
Timepieces Watches Manuals CASIO
Jun 11, 2014 | Casio Pathfinder PAG60-1AV Watch
My casio exilim battery shows low battery even after charging completely.
Rechargeable batteries, unfortunately, do not last forever. The older the battery and the more it's been used and recharged, the shorter the life. You will get to a point where the battery will only last 30 minutes or so, and will take only 20 minutes to charge (if you have a charge indicator for you battery).
My suggestion is to look online for a replacement battery. There are many places that sell generic batteries that work very well, so you don't need to spend the extra money to buy a real Casio battery. Just do a search for your battery model number.
Good luck.
May 09, 2011 | Casio EXILIM ZOOM EX-Z60 Digital Camera
I've removed the back of my casio db-36 watch, but I can't figure out how to remove the battery. The watch went blank last week.
There is a clip over the battery and then down on one side. You need something tiny and sharp... like a needle. You can insert the needle into the clip between the battery and the outside edge of the clip and gently pry the clip out and away from the battery.
Feb 06, 2011 | Casio DB36-1AV Wrist Watch
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
My solar powered 50-lap Ironman died after 1 month of normal use! Now it just stares blankly at me until I press any of the buttons, in which case it goes back to 12:00 and works for a couple of minutes...
I have exactly the same problem with my solar powered Casio watch.
I discussed it with a good jeweler and he explained that when you have sun, the watch 's battery will be charged up. But when the battery's charge is used up it works off a capacitor power source. But if the capacitor is defective(no available backup power) you then end up with a blank display. And it'll display the default settings(12:00) for a while only.
You can have a jeweler change the capacitor to get it working again.
For my $100+ watch, it'll cost me about $25 to replace the capacitor.
But for yours, the watch may not have cost that much and therefore
be hard to justify that cost.
I hope the explanation was not too technical for you. Good Luck.
Jul 21, 2009 | Timex 27191 Wristwatch
Casio Pathfinder PAG-50 battery replacement
ensure all three of the springs are present
the 2 at the top confirm that the case is closed the on at the bottom sends the sound signal.
ensure the metal casing on the back of the movement is not touching the back. and check the movement is correctly seated
Mar 28, 2009 | Casio Watches
Watch is blank/not charging
The watch started working by itself.
Jan 18, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Casio G-Shock GW-300 2608
Change the battery. This happened with mine along with the battery needing charging more frequently. In my opinion, Casio's assertions that you won't need to change the battery is pretty much of a joke. My jewler concurred.
After changing the battery I can now press the light switch button and the watch works normally.
Tony
Feb 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Feb 23, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Televison & Video Logo
27 people viewed this question
Top Casio Televison & Video Experts
mikeuk
Steve Allison
Steve Allison
Lawrence Oravetz
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
