Question about Hitachi Televison & Video
FIRMWARE FOR Hitachi 40HXC06 - Hitachi Televison & Video
I have an Hitachi LE55W806. The hdmi inputs quit working, the AV and component inputs work fine. I've been told to replace the main board, but can I repair it instead?
If the AV and component inputs are working, HDMI should also work. If the HDMI DDC has not installed properly by the firmware, the HDMI won't work. In your TVs case, an update should make it all right. Contact any well experienced service technician or the authorized service center for Hitachi. Firmware update to Hitachi brand devices are somwhat difficult to a normal user. If you wish to get some details; check the site linked here. Pull up older posts.
Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Aug 02, 2016 | Hitachi Televison & Video
Hitachi stuck on hello when switched on
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 15, 2015 | Hitachi Televison & Video
My 50Hda39 50 in plasma doesn't work through the coaxial cable hook up
Please contact the authrized service center for Hitachi. Sounds like corrupted firmware. Firmware update is necessary, and the firmware to Hitachi is very difficult to get by internet. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 26, 2014 | Hitachi 50HDA39 50 in. Plasma HDTV
Firmware update for Hitachi 51F59 51 in. HDTV Television
You need to set up the wireless internet connection in the TV to connect to a wireless router and then the TV will download the firmware update over the internet.
Dec 17, 2012 | Hitachi 51F59 51" HDTV Projection...
I am trying to upgrade firmware on a hitachi 42hds69, using a 2 sd card, I formatted the new card before uploading the file, I did unzip the file on my desktop. The tv won't do the upgrade. any Ideas
I had an issue (OTA no audio in channel 2-1 and 11-1) on my Hitachi 42HDS69 so I tried to upgrade the firmware. The manual as well as the instructions on TV all state to use a MMC card. Someone on an internet forum also stated that a 7-pin MMC is needed. I tried exactly that but it did not work. Finally I tried a 128MB SD card and it worked like a charm. The firmware upgrade fixed my OTA audio issue. I went from V0108 to V0125.
All you need to do is to extract out the .F02 file and place it in the root directory of the SD card.
BTW, I did call Hitachi customer support. They refused to help due to the TV is too old (about 10 years old).
I guess it all depends on who you speak to at Hitachi?!
Feb 09, 2011 | Hitachi 42HDS69 42 in. Plasma Television
IC25n020ATMR04-0 firmware how can i remove the firmware and replace it
certain utilities from salvationdata or acer lab can help one do a firmware back up and restore, also certain hard drive companies like seagate and wd have firm ware backup and restore utilities,hitachi has its firm ware saved in three places on the harddrive in the SA areas as SA A SA B AND SA C. one has to have hdd hitachi from salvation data to back up firm ware , which i feel is an expensive affair. or just go to a recovery guy and ask for firm ware upgrade done by salvation data or acer equipments
if the charges are exorbitant , let me know the firm ware of your hitachi drive and i will try to give it to you. pm me if you are not in a position to back up by any of my recommended methods
datarecoveryfactory
Sep 04, 2009 | Hitachi 08K0632 (ic25n020atmr04-0) 20 GB...
Hitachi DMP250N undetectable after interruption in Firmware updat
there is a reset button on the side of the mp3 player. If you get a pin and insert it into the hole it will reset the unit. good luck.
Apr 30, 2009 | Audio Players & Recorders
Need drivers for hitachi model gsa-h21n dvd burner
drivers are not needed in order to cd to work, but this problem has aleazrdy been registered.
you shoul click on START, RUN, and type "regedit"
then search in the tree the branch
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
in this, remove the Upperfilters & Lowerfilters values.
reboot, it should work
if really not working after that, download and install the firmware update you can download at http://drivers.softpedia.com/get/FIRMWARE/LG/LG-GSA-H21N-Firmware-A03.shtml
Nov 24, 2008 | Hitachi LG GSA-4120 DVD+-RW/RAM 12x Burner...
Televison & Video Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
