Question about Polaroid Televison & Video
I've got a Polaroid 55 inch Fhd LED and I've swapped the tcon board but still no backlights. Sound and display are functional.
Check picture set up for backlight
SOURCE:
SOURCE: Is the video processor board the same thing as the tcon board on a sony lc42d62u? Have sound, no picture. I have replaced backlight inverter boards & main board. Could it be the tcon board?
yes it could be a t-con board but could also be a 12V power supply output failure. The Video processing board, and LCD panel uses 12V
Posted on Oct 14, 2012
  • 3 Answers
SOURCE: Vizio E550i-b2 TV has no backlight, pic or sound. Replaced power and Main boards - still having the problem. Any suggestions? I have the TCON and LED Driver board left
The led is what makes the picture try replacing that it it's the only one you didn't change out
Posted on Aug 31, 2016
gopakumarg43
  • 76046 Answers
SOURCE: Wondering how to diagnosis a 55 in samsung led tv with solid blue screen. It has sound.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. The fault is related with the video processing section circuit at the main digital board. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Oct 23, 2016
  • 2794 Answers
SOURCE: How to test Tcon and other board on Vizio television. When I first connect power logo is bright orange, then slowly dims.
That isn't a timing control board issue, see if you have PSON voltage for starters, if you do then test the various power supply voltages, it could be either the main or power board giving issues, but I would bet on the power supply is bad since the logo comes stays on
Posted on Jan 31, 2018
  • 2794 Answers
SOURCE: Have Vizio E60-c3 LED TV. Picture not working, Backlights on, Audio works. Ordered Complete repair kit from Shop Jimmy.
About 99% of the boards from shipjimmy are good, unfortunately lI think you have a bad panel and its destroying the tcon board, did you check the fuse on the tcon board?
Posted on Feb 21, 2018
Hi, We have a 55 inch LG smart TV that has sound but lost picture. It is not under warranty, so we took the back cover off. Backlights are on and working. How do we determine Tcon board vs LED driver?
if the back lights are on then it's not the led driver. it will be the tcon board or cable. try wiggling the cable and connection and see if the pic come on. can also need reseating and that means unscrewing and removing the board and disconnecting the flex cables to the screen. clean the cable connections on the screen cable with a toothbrush and nail varnish remover (cheap stuff) and wipe dry. then refit and see if that works. if not it will be the chip has become unseated and need reflowing or replacing but just as simple to replace.
Apr 17, 2018 | LG Televison & Video
Samsung un60d6000 tv no picture only sound?
the voltage is ok doo you have constantly 150 v if not led blocks is bad
Feb 28, 2017 | Samsung UN60D6000 60 Inch 1080p Smart TV...
Hi I have a Hitachi 55 inch LED tv Model#LE55V707. I have sound but the picture is a solid blue Square covering the picture. Is there an easy fix to this please?
The TCON board or the LCD panel is faulty, Can confirm by replacing the TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 03, 2017 | Hitachi Televison & Video
Sony Bravia KDL-40EX500. Plugged in power and no backlight. No pic no sound. Could it be the power board or inverter board? How can I test these boards? Thanks.
SELF DIAGNOSIS FUNCTION
The units in this manual contain a self-diagnostic function. If an error occurs, the STANDBY LED will automatically begin to fl ash. The number
of times the LED fl ashes translates to a probable source of the problem. A defi nition of the STANDBY LED fl ash indicators is listed in the
instruction manual for the user's knowledge and reference. If an error symptom cannot be reproduced, the remote commander can be used to
review the failure occurrence data stored in memory to reveal past problems and how often these problems occur.
DIAGNOSTIC TEST INDICATORS
When an error occurs, the STANDBY LED will fl ash a set number of times to indicate the possible cause of the problem. If there is more than
one error, the LED will identify the fi rst of the problem areas.
Result for all of the following diagnostic items are displayed on screen.
If the screen displays a "0", no error has occurred .
Diagnostic Item
Description
Number of times Standby
LED blinks Possible Location
Main Power Error 2 G2HE/GD2 (Power) Board
Audio Error 3 A (Main) Board
Balancer 4
LCD Panel
Inverter Board (ETC-Inverter MT Board) for 32" & 40" Models
TCON Error
5
LCD Panel
TCON Control MT Board
HFR Error 5 LCD Panel
Backlight Error 6
LCD Panel
Temperature Error 7 A (Main) Board
This should help you narrow it down. I am also attaching the service manual for you. https://files.acrobat.com/a/preview/16a56e45-a439-48bc-8770-21638f2bab68
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jul 04, 2016 | Sony Bravia Kdl-40ex500 Series 40-inch Lcd...
Good sound no picture at all. No backlights but I can see the menu screen with a flashlight in the dark. Do I change the tcon, main board or the power supply? Thank You
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 01, 2016 | Hisense 55K22DG 55-inch 1080p 120Hz MHL &...
Sound and Backlight, No picture
You really need to know if you have power to the Tcon with a meter check on the fuse on the Tcon to see if you have 12v .the fuse will be marked F*** it does not look like a glass fuse
Nov 18, 2015 | LG 32LN5300 32" LED TV 1920x1080, 60 Hz,...
Televison & Video Logo
35 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
