Setup error or incompatible EEPROM
Control Microprocessor Version
Ask for EEPROM Spare Part indicating Microprocessor version
Reflash EEPROM
Check electronic controller
F10: Pressure Switch Empty and Full or neither Empty nor Full
Pressure Switch Found
Overhaul CN1
Overhaul Pressure Switch Wiring
Control CN1/Pressure Switch Continuity
Replace Pressure Switch
Replace Card
'F10' for Indesit (Hotpoint, Ariston) decodes as 'pressure switch, check PS, wiring and module' which sounds major BUT is not uncommon in this make of machine and is often caused by poor contact between plugs/ cables and the control PC, just needing re-seating- by an engineer ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
You are on the right track, you need to thoroughly check all connections to and from the pressure switch and the control module
iT is not the pressure switch itself that is usually faulty.
