Restart in safe mode, by simpally pressing the f8 key while it’s turning on, and simply uninstall anything new you’ve installed. Hopefully this would be enough, if not you need to install a new windows.
Right click your mouse, anywhere on the screen, when the small window opens click on view then make sure there is a check mark by "Show Desktop Icons"
OP you posted to a USA forum the county that has NO PB computers here sold here after
1999
then support ended, like 2 decades now.
no PC posted by you,
nor your country,
the support varies (if at all) by those 2 factors
here is the one clear line in wiki a quote.
A GEM!
In 1999, NEC began withdrawing the Packard Bell name from the U.S. market, while keeping it in Europe, where the brand was untainted by allegations of sub-standard quality seen in uSA.
In 2008 it was acquired by the Taiwanese consumer electronic firm Acer.
Finding support with PB can be a big pain.
if the task bar and DT icons all are missing
it can be caused by Kids playing.
but no OS stated, windows what?
if the task bar is present but the start BUTTON MENU is deaD (UP TO WIN7) THEN THE PC IS INFECTED
op
why not post of photo of screen wrong.
we are USA forum
did you buy said PC in USA if not say where
our support is not for outside USA<
(I am talking PB support at BP.com)
monitor dead, OSD menu button dead.
PC fans spin and blow air both fans?
if not fans spin PC is dead.
if all above works ok
then check bios screens next.
the monitor tells you when you turn on PC
what keys to hit for BIOS.
do that , get bios working first.
BIOS screens. must work. first.
what menu, what icons
do tell, we can't guess what you expect
must be said.
It's a PB what else would you expect from junk like this? sorry.
start up , windows login? missing?
or desktop start button missing in task bar?
or desktop icons gone above the taskbar.?
be more specific and answers can be right.
tell what works right and not.
both, as we can't watch it boot and see so....
SOURCE: The desktop is empty
First a question; you say you only have the background and cursor does that mean literally everything else is gone including the start button in the lower left and the task manager in the lower right? Or do you mean that all your icons, shortcuts, folders and files you had on your desktop are gone?
SOURCE: Cant take apart packard bell imedia to install pci card
when disassembling server chasis, you will have to release the front panel first, only then you can remove the side panel
SOURCE: Hi, I have a Packard
What OS do you have? Is the keyboard responsive when you get into the operating system? Did you install anything the last time it worked fine?
SOURCE: start menu and desk top
Can you start it in Safe Mode? Press F8 while the computer is booting. click on Safe Mode with Networking when the menu comes up.
When you get into Safe Mode, run you anti-virus. And clean your Cookies, Temp files and Internet Temporary Files. And while in Safe Mode, run a defrag of the C: drive. Restart the computer and it should start up correctly.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: start menu toolbar does not appear on desktop
Here's a couple of things to try:
Press Cntl+Esc key. That should bring up the Start Menu. Maybe the menu is hidden on one of the sides, or top. If it is, click it and drag it back to the bottom. if this doesn't work:
This problem can also occur when you are infected with a virus that seems to be unreported on symantec or any of the other anti-virus resources I've found.
If you can get to task manager go to the Processes tab, and look for a process called 'SYSU.EXE'. If it's running, kill it.
Now, if your desktop suddenly returns to normal, then yes, you've got this virus. You're not out of the woods yet. There is probably a folder on your machine called 'C:Program Filesddm'. Delete that, of course. You'll probably also want to search your registry for the string 'ddm' and kill most of what you find. In particular the key HKEY_LOCAL_MACHINE/SOFTWARE/ddm, and anything under HKEY_LOCAL_MACHINE/SOFTWARE/Microsoft/Windows/CurrentVersion/Run and/or Run once that refers to 'ddm' or 'sysu.exe'.
As usual, I'll include that this entire procedure is something you should undergo with great care, or leave to a computer guru friend if you're not comfortable with it.
found this at:
http://forums.devshed.com/windows-help-34/no-start-menu-or-icons-on-desktop-winxp-66403.html
Hi Suyin , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
PB does not sell PCs to USA customers
so are you in EUROPE with the DUTCH made PC
called BP -B.V?
no PC stated,at all,(no model name number)
no OS stated,at all ,windows, yes, have version.
no country stated,
so answers come hard or late.like this.
you posted to uSA website fixya, PB ended sales here in 1999, 2 decades ago.
but made them in Dutch factory.
in 2016 PBX sells junky PBX laptops in JCpennny;s as they close 140 stores, wow.
