SOURCE: Ricoh Aficio 2018D
This could be a very bad code its "main motor lock", either you have too much load on the drive unit ( paper stuck, locked up pcu or fuser ) and maybe bad BICU board.
-Carl, please let me know if this helps.
SOURCE: Não Consigo acessar Serviço de
helo
Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Check the Primer Tubes. Reconnect the power cord and
power On the Printer.
Perform the Service Station diagnostic test to troubleshoot the problem
further
If the System Error continues, replace the Service Station .
If the System Error continues, replace the PrintMech PCA
SOURCE: tenho uma ricoh 171 esta
You have a main motor overload. This can be caused by a defect in the photoconductor unit. Try putting an old photoconductor unit. If you still can not run the engine is broken
SOURCE: estou com uma tv rca
please can you rephrase this question in English?
I look forward to your reply.
Bye for now.
SOURCE: laser aficio 2045 (erro322)
ola ha a possibilidade de voce desmontar a LD INIT e limpar o LED do laser e os espelhos que ficam dentro do laser.
e um pouco trabalhoso mas da certo pois o toner derrama dentro do laser e ele nao consegue mais sincronizar.
precisa retirar 6 soldas das tres pernas dos 2 leds e retirar os parafusos.
