Question about Sanyo Refrigerators
My sanyo refrigerator's freezer isn't working well, it's cooling but not making solid ice. Sometimes it's making weird sound like not the normal refrigerator sound. I sometimes need to unplug it for like 5 hours for it to run normal again and produce a little bit of frost.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
To check in door fan ok
Posted on Dec 25, 2018
    Genius:
  • Sanyo Master
  • 2,548 Answers
Make sure its level,turn up the theremostat or replace it what ever is necessary.
SOURCE:
SOURCE: 5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Posted on Mar 18, 2008
SOURCE: refrigerator keeps running
I have the same problem. I called a service rep for G.E. and he said that there are 3 thermodisc
sensors behind the white evaporator cover. He gave me a price to repair that was completly out
of range for the problem. I paid him for his service call and sent him on his way. I then decided to
to order the parts from a factory online parts center at less then half the cost of my estimate not
to mention that when I was ordering the part the Factory emailed me a complete parts breakdown showing the Thermodisc and that my unit only has 1 thermodisc not three installed from the factory.
I ordered 2 one for a backup just in case. I deiced the buildup and installed the disc after 24 hours the refrigerator was working normal for about 4-months. Once again the refrigerator iced up and stopped cooling so I called the factory tech support and they told that it is normal to have some ice on the cover of the evaporator and the thermodisc is at that point supposed to open the cooling circuit to let the unit go into defrost mode and then close again. The Tech said that I had a bad
Thermodisc again so I put the spare one that I ordered in and it also worked for about 3 months
now I have the same problem ????????
Brad
Posted on Sep 14, 2008
rafaelrs38
  • 12 Answers
SOURCE: freezer and refrigerator stop cooling, back of
clean all the dust and form the gril on the back of your frig
Posted on Aug 10, 2009
  • 109 Answers
SOURCE: Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Posted on Oct 22, 2009
heatman101
  • 43501 Answers
SOURCE: GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Posted on Sep 29, 2010
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Apr 14, 2015 | GE Refrigerators
Freezer doesn't cool to 0 even though it's set at -5
There is a fan that blows air past the coils in the freezer. Either the fan is not working or the coils are blocked with ice. Sometime ice stops the fan from turning. listen for the fan spinning by turning the thermostat down. Defrost the coils and fan and see if the frig returns to normal. Sometimes the drain tube is clogged causing ice buildup.
Feb 13, 2014 | Whirlpool GB2SHKXL Bottom Freezer...
Fridge isn't cooling
Its defrost issue.The defrost assembly parts are not functioning right causing the problem.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Kenmore Side by Side Refrigerator
Cannot adjust contol to freezer and no sound to the compreeor
May be faulty compressor or issue with compressor control capacitor.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Zanussi Z57 / 3 Bottom Freezer...
MAKING ICE TOO SLOW
A lot of times, the reason ice production slows down is because the freezer isn't cold enough, usually because the freon level of the machine is low. Sounds weird, but even though the freezer is below 32 degrees F, which is freezing, the ice maker requires the temperature be below 10 to function properly. Another cause for the temperature not being cold enough is if the coils are dirty and ther machine is passing the heat to the machine itself
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 30, 2012 | Maytag MBF2556HEW / MBF2556HEB /...
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
Refrigerator section does not cool; freezer works fine
Check the settings first. They should be set to the factory settings in most cases. Otherwise check the back of your freezer to see if it is icing up, you may need to remove the back panel to see the ice. If this is the case the ice may be preventing the fan to circulate the cold air into the freezer and you will need a new defrost timer. However if there is no ice and the fan never kicks on you may need a new fan motor.
Jul 05, 2009 | Kenmore 73752 / 73754 Top Freezer...
My refrigerator is acting weird!
Hi. thanks for the question. I would check the fan motor, in the freezer. cut power to the fridge. remove back panel. replace the fan motor. clean all ice at the bottom of freezer. clean the drain ,from freezer to the back by the compressor thanks the appliance doc. please rate my answer.
Oct 05, 2008 | GE GTS22WCP Top Freezer Refrigerator
Refrigerators Logo
59 people viewed this question
Top Sanyo Refrigerators Experts
Marvin
Marvin
Bailey's...
Bailey's...
Albert Nairn
Albert Nairn
Level 1 Expert
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
