SOURCE: hobart amx/aux-s dishwasher "bof" error code
press the 1st and third buttons on the display nxt to the start button then press the start button,this will change the the display to something like BOF1 then allow the achine to fill the rinse tank you will know when this has happened as the display will go out (all of it) then you can turn on the machine using the button marked with a I the start button will light red allow it to go green and you are ready to go ... if when you are boffing it it changes to FIL the your water pressure is to low good luc fella
SOURCE: E5 error - need to know where drain hoses are
tried to take off the drain hose, but could not get it off the back, only by the disposal. I turned if off and on about 6 times and ran the delime cycle with lots of limeaway. It got the E5 error on the delime cycle, but it worked the next time I tried to run it.
The manual does say to turn it off and on as it drains out the water. Takes a while as it has to heat up the water each time.
SOURCE: Hobart dishwasher model LX30H displays -5 on
by the way you're describing the problem, i would have to say there is something wrong with your control board. part#473173 can be bought @ any hobart office in your area. dont forget to vote
Testimonial: "Turns out it was mice eaten wiring."
only a suggestion is it heating up what i remember it want move on until it heats up to it's working temperature, good luck
