Control board should flash
Here is a list of the Whirlpool fault codes:
https://producthelp.whirlpool.com/Laundry/Washers/Washer_Product_Assistance/Error_Codes_in_Front_Load_Washers
SOURCE: whirlpool front loader
please clarify the "some times throughs the switch" part...does the timing switch continue to run even though the machine stopped?
SOURCE: sour smell coming from inside whirlpool duet front loader
Residual water sits inside the wash tub under the stainless steel basket and in the drain lines & drain pump. This is normal. If you are in the habit of using very few hot water cycles and do not leave the washer door open when not in use, bacteria, mold and mildew can build up and cause the sour smell you are experiencing. The following link provides some good info on how to prevent these odors:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
You may also want to remove the drain pump reservoir and check to see if you have anything caught. Sometimes debris can build up in the drain pump and cause odors. The following link explains how to check the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I personally own a front loader such as yours and have never had a problem with odors by following this simple advice. Occasionally run a sanitary cycle with nothing but bleach in the water. For washers with no santitary cycle, run it on the hottest setting you have. Sorry...front loaders require a bit more TLC than conventional top loaders. I hope this helps you. If you have questions, please let me know.
SOURCE: whirlpool front loader error code
hi thanks for your question. i would check the pump remove the front panel 2 screws on the front panel at bottom remove you will see a big plastic nut in middle un screw but you will get water put a bucket under this nut pull out and clean . this will solve your problem thanks the appliance doc
SOURCE: F-02 error code on whirlpool front loader duet
F/02
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
