Briggs and stratton 13.5hp i/c 2005 model
SOURCE: 6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
SOURCE: Briggs and stratton engine surges and slows, repeatedly
There is still either water or debree contaminating the fuel system. Surging is usually debree, empty and flush the tank with gas or Iso alcohol, disassemble carb soak in solvent for 30 minutes blow out the carb passages, reassemble and if the problem persists run engine at top rpm with air cleaner off and block off carb intake with hand, this will stall the motor restart and repeat 4 - 5 times this wiil draw out any debree or other blockage in the carb.
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
SOURCE: A briggs and stratton 450 series 148cc on a moter
More than likely, it is the main jet is partially clogged. That is the brass bolt that holds the float bowl onto the body of the carburetor. Remove this bolt and washer and clean it well. Use no metal objects to clean it.. Make sure the bottom hole and the side holes near the top are clean and clear.Carb/choke aerosol spray should do the job here. Use no metal wires or scrapers on the jet. Clean until shiny, reinstall and try starting the machine.
