It turns out that taping button A once quickly by itself switches the MD0699 between military and regular time.
SOURCE: armitron black all sports watch WR 165
Download a manual from their web site to tell you how you how to set it. See download web site below.
http://www.armitron.com/watch_instructions.asp
SOURCE: How to set an Armitron WR330 Watch
he following labels are on the inner ring of the watch; I've given
their positions relative to where numbers would be on the face of an
analog watch.
"ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
To set the time, date, and day of week:
Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
Press the ""ST/STP" button to change what you want to set. The
options appear in this order each time you press the "ST/STP" button:
minutes, hour, month, day, day of week.
Use the "ADJ" button to change the value of the setting.
Touch "MODE" to save the settings and return to time mode.
The website listed below has many instruction sheets, but does NOT have instructions for this watch as of 25 December 2008.
Check:
http://www.armitron.com/WatchInstructions.html
SOURCE: need manual for armitron sports watch 40/8172
Go to the Amitron web site , "amitron.com".
Select "support" and the "watch instructions" from the drop down menu.
There will be a number of illustrations
Using the arrow heads on the right, scroll down to the bottom and select the one marked "mens digital".
This file contains the instructions for two manuals, the one you want is the second one (scroll down to reach the 40/8 series).
Testimonial: "Thanks man,just what I needed!Great tip!"
SOURCE: Watch is Beeping loudly on every hour!
While pushing and holding the RESET button in, press the START button to toggle between CHIME ON/OFF.
SOURCE: My TGHK watch is stuck in ''Military Time''...
advance the hours. The first time you go through the 24 hour cycle, it will be in am pm mode, the second time in 24 hour mode, the next time in am pm. Just keep advancing the hours until it comes up the correct time
