Question about Razor Toys
Razor mx650 won’t start, wire running from the throttle, has 2 wires that aren’t connected anywhere, could this be the issue?
    Top Expert:
  • Razor Master
  • 84,540 Answers
Yes it is
Posted on Dec 14, 2018
SOURCE:
  • 189 Answers
SOURCE: Old mercury thermostat, New furnace wiring issues
Two wire hookup on the old thermostat tells me that it was set up for heating only. You will most likely need a modern thermostat. But in the meantime try this with the old one. The two red wires on the furnace are probably Rh & Rc. If so these can be put "together" on the R terminal on the old stat. The two W's on the new furnace are probably W1 &v W2 This is for first and second stage heat. You can put the two "together" on the W terminal on the old stat. Do not hook up the greens (blower fan wires). Do not hook up the blue wires (They would go to the Y terminal on a modern stat for airconditioning.
Who ever sold you the furnace should have offered you a new thermostat.
Good luck....
Posted on Apr 10, 2009
SOURCE: alernator wiring issues
that plugs to the oil senser right below the alt with a screw on it 9-10 it broke off but it screws on
Posted on May 03, 2009
SOURCE: Early model Razor MX-500. Replaced motor, control
the back wheel won't move it try to move but it won't it's making a loud noise.every time you give it gas.what could that be...
Posted on Dec 26, 2009
  • 396 Answers
SOURCE: Hooked up scan machine to
Start with the cigarette lighter fuse. Usually on the same circuit.
Posted on Nov 17, 2010
SOURCE: bought a used razor mx500.
Did you ever solve this problem?
Posted on Dec 03, 2010
How to replace mx650 Freewheel Clutch
You can buy a tool online that grabs the free to turn it off if the wheel center hub. Looks like a socket with 4 teeth.
Jun 20, 2014 | Razor MX650 Electric DirtBike
Low power
Yes, your batteries need replacement, that will solve the problem.
Mar 19, 2013 | Razor MX650 Electric DirtBike
Rear wheels won't move chain just spins
I posted a solution to this previously, please check it out.
Aug 27, 2012 | Razor MX650 Electric DirtBike
Razor MX650
It is the rear freewheel assembly causing the problem. if is fixable, but you have to be good with tools, the bicycle shop and the electric bike shop both said they couldn't fix it, but is is doable. 1. you need a special bmx tool that fits that back wheel, your local bike shop should have it in stock. 2. you need to remove the freewheel sprocket and disgard it along with the the bearings (make sure to unscrew the razor chain sprocket from the freewheel assembly and secure it for reuse). 3. either purchase a new freewheel sprocket for bmx wheel or remove one from a old bike (again you will a special tool for that). 4. screw the razor chair sprocket onto the new BMX sprocket (it goes on with the same 4 original screws, right over the sprockets. 5. Screw the freewheel back onto the rim now. tada its fixed.
Jun 03, 2012 | Razor MX650 Electric DirtBike
My razor mx 500 motor won't turn.
I think you are talking about an electric motor on your bike . If the motor is New you may have a bad throttle switch . You can use an ohm meter to check the throttle switch . Connect the two leads of the ohm meter to the wires of the throttle switch ( dissconected) . As you turn the throttle the ohm reading should coraspond to how much you turn it .
Jan 15, 2018 | Razor MX500 Dirt Rocket
Battery charger shows charged. however when tun throttle, nothing. no indication of loose wire connections. have a pocket mod
Make sure it is not battery or motor, jump the battery + & - to the motor + & -, if it works it will be the control box
30 minute fix for very cheap
ITEMS NEEDED
Get a Potter & Brumfield relay (5 poles)
2-3 feet of wire
4 female wire ends to plug into relay
HOW TO FIX
Take apart razor so you can see the black control box
Unhook throttle plug, this is the one with 4 wires (2 brown & 2 orange on mine)
Wire relay:
85: Ground
30: Red wire from switch to control box, if you wire this straight to battery it will work with switch on or off (killing battery)
87: Red wire to motor
86: Brown wire from throttle plug
Run a wire from 12v (battery) to other brown wire on throttle plug
END RESULT
When the throttle is activated, it closes the loop in the brown wires, triggers the relay, activates the motor
You WILL NOT have the throttle control, it is wide open or off when you activate/de-activate the throttle
This will save you $30 for a new control (brain) box.
Jun 10, 2011 | Razor E100 Electric Scooter
How do i adjust the chain on the mx650
The chain tensioner is on the right side of the bike a few inches or so in front of the tire on the rear swing arm all you do is adjust it up to tighten and down to loosen it.
May 30, 2011 | Razor MX650 Electric DirtBike
Toys Logo
80 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
