Coffee Makers & Espresso Machines Logo
Kumudha Ramanathan Posted on Dec 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Saeco Odea giro plus , bought in 2011 . When I turned the machine on this morning, the power went out after the cleansing cycle. Unable to power on . Unable to remove brew group
timoboon2
Level 2:
Sergeant:
  • Expert 360 Answers
  • Posted on Jan 15, 2019
timoboon2
Expert
Level 2:
Sergeant:
Answers
360
Questions
0
Helped
154494
Points
959
Sounds like the main fuse had blown. Probably because it pulled too much power through the heater while cleansing.
1 Related Answer
Anonymous
  • 515 Answers
  • Posted on Aug 02, 2008
SOURCE: brew group on saeco odea giro wont go back into machine
try to put in the dregbox to the machine, close the door and power on the machine. When the machine not make any noise, open the door and put in the brew group.
3helpful
How do I prime the saeco odea giro plus?
Hi, open the steam/hotwater outlet while its heating. It allows the air to release and water to fill the void. Dazza. Enjoy your coffee
1helpful
2answers
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
2helpful
My apparatus SAECO ODEA GIRO doesn't light on anymore Thanks for your help
Thermal switch has tripped on the boiler and can be reset by pushing in the pin. Or more seriously can be the circuit board failure.
2answers
Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
3helpful
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Det røde lys slukker ikke på Saeco Odea Giro plus Kaffemaskine er helt ny kun brykket to kopper kaffe
is it the green flashing light? If so it is the thermostat that needs resetting. You can return it for repair, or I have made a website explaining how to do it yourself. http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
hope it helps
Andrew
Saeco Odea Giro tuning on/off
turn off each night and when going away! the machine will last longer.. without repair! also saves money (they use alot of power!
2answers
Saeco odea giro
Yes it might be the main board. but i would first try reseting the Boiler automatic fuses
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
