SOURCE: FRIGIDAIRE REFRIGERATOR PROBLEMS
Freezer stayed cold but upper compartment wouldn't. Freeze started having problems with staying cold. I just paid $377 to get the two year old evaporate fan replaced. It is located inside the frig behind the panel in the freezer compartment. It took about 15 minutes. Seems this part is part of the evaporator system but not covered by anything other than the first one year warranty. Problem solved but what a ripoff from Kitchenaid.
SOURCE: 2003 Frigidaire FRS26BH6CBO Side By Side Problem
DEFROST PROBABLY SET TO AUTOMATIC..NEEDS TO BE REPLACED THEN ALL WILL BE WELL
SOURCE: EF error code on frigidaire
My Frigidaire also got the dreaded E-F error code and stopped cooling. Technician over the phone told me to unplug it for 5 minutes and then plug it back in to see if the control board would reset itself. Did that with no luck. Unplugged the refrigerator last night while I tranferred my food to a spare fridge in the garage. Plugged the fridge back in this morning (9hrs later) and it works fine with no error codes. It looks like the control board has reset itself but how long it takes...I dont know. 10.. maybe 15 minutes? Well more than 5 at least. Guy over the phone told me that you can buy DRY ICE at a local grocery store and put it some in your freezer and a little bit in the frigdge to keep the food cold for a day. I had a spare fridge but I thought that was a good tip for anyone that needs to buy time for a tech to come repair the fridge. I had just bought $300 in groceries the night before so that tip would have come in handy if I did not have the spare fridge. I have no idea what the EF error was for but it's been 5 hours since I plugged my fridge back in and it's running fine so I'll cross my fingers. Got around to cleaning the fridge and plugging in a surge protector too. Hope this post helps someone out there.
SOURCE: refrigerator side not cooling, but feezer is still freezing
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE LOWER AREA OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. THE HEATER IS THE MOST COMMON. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING THE DEFROST HEATER. 95 PERCENT CHANCE. JUST REPLACE THE HEATER SOON AFTER DEFROSTING SO YOU DONOT HAVE TO DO IT AGAIN.
SOURCE: My Frigidaire Gallery display says
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
