SOURCE: I have a nobis Tablet.I tried to do a hard reset
guess is that the float level is not closing (need to open float bowl and clean everything inside with carb cleaner. Confirm that the float is operating (up and down) . Reassemble and try again...should be fine.
SOURCE: Proscan tablet Plt8235gbt-kbt is stuck on android
O/S corrupted. Contact the authorized service center. O/S might have to be re-installed.
Electro help
SOURCE: factory reset set my android tablet
Most tablets have a very small reset button on the housing press in with a paper clip and hold for a few seconds then release . Others go into settings and reset from there .
SOURCE: nobis tablet stuck on go
My nobis tablet keeps on resetting what can I do,to stop it from resetting.
SOURCE: How to do a factory reset on a Nobis 7.85 tablet, it is blocked
Follow these steps:
1. Press the power button and the home button together or Power button and Volume button together for a while, long enough till the Android boot mode screen appears. Press home button to reach the options under boot mode. Navigate through the options using volume key and select "Wipe Data Factory Reset"option using shortcut menu button. Again navigate to the option "delete- all user data" and select it using shortcut menu button. (Make sure memory card is not inside; otherwise the data on it will be lost). After the data is deleted, a message saying "Data Wipe Complete" appears. Press the shortcut menu button to reboot the tablet again. Now, your tablet is as fresh as a new tablet
