Go into picture set up
SOURCE: HDMI Cable - No Sound L42WD22 RCA Flat Panel TV
No sound and a digital picture. i will assume you have no signal on analog rf cable. Thomson(RCA) have been having problem with these sets. The trouble stems from the digital cuircit board. We see alot of these. You used to get the digital board.. they are not availble.. so rca found the component on these that fail.. A VERY SMALL surface mounted fuse. With a lighted magnifer and some fine tip twezzers. we replace these fuses on these boards. Do you have any soldering experence..
SOURCE: no picture no sound
Select proper input signal or check signal connections in the back. Attempt to use buttons on TV insteal of remote.
SOURCE: no picture on Pioneer Elite Kuro 60" inch plasma
my pioneer pdp 505hd tur on ok but the picture no working and no sound ,can you help me please
SOURCE: no picture on flat panel tv. has sound
Sounds like the digital control board, 6871qch038a Lg Digital Control Module subs to 6871qch038c. But that's just a first something I would check in this unit. Replace also capacitor C19, 630V big blue square cap very common failure for no video. You might want to shop this one thee are a host of problems with this unit that would certainly get some needed attention if a qualified tech were testing it and looked up the bulletins.
Good Luck!
William Rayburn, CET
Premium Technologies
SOURCE: Sharp lcd flat panel TV model 26sb24U no sound or
It is still under warranty, bring it to sharp authorized service and thay will take care of it.
