Question about Hotpoint Washing Machines
I have a Hotpoint Aquarius+ WDF740 washer/dryer that is noisy on the spin cycle. It sounds like the drum is out of balance.
So far I know that: 1. When turning the drum manually it turns smoothly without resistance or noise 2. There is no vertical or horizontal play in the drum when trying to move it from the front 3. The concrete block on the top is securely fastened 4. The springs and dampeners look OK I think I can feel another concrete block to the bottom right of the drum (when viewed from the front of the machine). The problem is, I cannot access this area to check if this is a concrete block or even to tighten it (there is some play in it when I get hold of it from above). Is this another concrete block that should be tight, without play? How do I access this area to tighten it? Am I looking in totally the wrong area (should I be looking at a worn clutch or something else)?
5 Suggested Answers
SOURCE:
  • 116 Answers
SOURCE: whirpool top loader unbalanced spin cycle
First change the springs - both the leveling and suspension. You may also need to change a few other parts on the brake and drive tube including the thrust ring. But replace the springs and let see what happens.
Post your results . Remember to rate this solution
Regards
Posted on Oct 04, 2008
TaPuna
  • 70 Answers
SOURCE: Washer constantly goes out of balance
1 option is to wind the back feet out so the washer drum will sit more to the front so as it less likly to hit the OOB switch, other thing is that the OOB switch might have corrosion on the inside of it and in this case if it gets moisture inside it during a wash it is more likely to go OOB, so try replacing it this should fix issue, if not replace Motor Control Unit. :)
Posted on Feb 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: Noisy Drum when washing/spinning on Hotpoint WD71 Washer/dryer
Your transmission is going bad.
Posted on Jul 05, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Posted on Jan 31, 2010
Testimonial: "Thanks for your help. In the end it was the front balance weight that had been gradually coming looser and looser and needed fixing pack into place."
How to fix, no spin on Hotpoint WDF740?
Long shot guess here but ...have you checked / replaced the carbon brushes of the electric motor ???? common problem I have had before.
If it is not the brushes then it could be segments of the motor burnt out which could be expensive.
Sep 07, 2014 | Hotpoint Washing Machines
Hotpoint 1200 wd62n banging noise when loaded but ok when its empty ?
There are many reasons that this could be noisy...
When you turn the drum (quickly) when it's empty does it rumble? Bearings, drum support or motor bearings.
If it sounds like a pneumatic drill when filled and spinning it could be drum support, bearings, balance weight or suspension.
These are not an exhaustive list but the usual suspects.
Jun 02, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Machine very noisy when it spins. Missing bra
If you cannot here it catching, then leave well alone, if it is still catching, then you could to try to locate it by removing the lower rear cover of washer, remove the large black hose on bottom of drum, and see if you can locate it from the bottom of the drum.
Hope this helps.
Jan 16, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Loud noise when spin drying, rumbling sound, sounds like concorde taking off! Hotpoint Aquarius 1200 washer dryer WD62
Remove rear panel of washer, and remove drive belt.
Spin the drum by hand, and if it feels rough, or is noisy, then the main drum bearings have failed, quite a big job to do.
Thanks.
Nov 07, 2009 | Washing Machines
Very noisy and moving around Hotpoint washing machine
there are four shipping bolts in the back of the washer that need to be removed they are long bolts connected to plastic pieces. unscrew them and remove the plastic pieces
Oct 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Started having a noisy rinse & spin cycle, then stopped.
Open the washer door and spin the drum by hand, if it feels rough or noisy and rumbling, then the main drum bearings have failed. There should be little or no noise when you spin drum
This is a major repair, and I would not recommend a D.I.Y solution.
Other possibility is there is something in the pump, but you would only hear this when the pump is working.
Plz rate my comments.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Bearings very noisy on the drum
aquarius w f 541 1400 spin drum bearing noisy
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
