SOURCE: dongle
I believe that the information that you have been given is correct. The VIP dongle is no longer available.
As for the second part of the question, do you have a damaged dongle or has it been lost completely? If it has been lost, there is no way to replace it without buying a new software package.
SOURCE: Dongle for Designer 1 not recognized in XP or Vista
Drivers can be found on Husqvarna Viking website (search for VIP software) under "other links". Here's the direct link - http://www.husqvarnaviking.com/us/8588_4197.htm
I don't think 3D/VIP is compatible with Vista but should be compatible with XP. Download and install latest driver per Husqvarna Viking website.
Good luck !!
SOURCE: dongle for sewing machine can't be activated
It could be you need a new software program or patch for the newer version of Windows.
Check with your dealer.
SOURCE: Designer 1 vip customizing is
I admit I did not think that VIP Customizing worked on Vista at all, but I now know that some people have got it going. Have you searched the www.sewmuch4retirement.com website (the late Jan Henning's website, which is an absolute gold mine of information for Husqvarna and Pfaff machines)? The other solution might be to partitition your hard drive and run Win XP on one partitition, and use that to install and run VIP Customizing. There are also Yahoo Groups specializing in Husqvarna machines and products. These groups have a lot of members with a wide range of machines, software and experience. I'm sure there is someone out there with a similar problem and someone else with the answer.
SOURCE: I have an older Viking program, Customizing
I'm sorry to tell you but your program will simply not run in your new Windows7 pc - it simply doesn't have the correct floppy connection driver for it.
Your only option is to either install XPMode or to dual boot. In XP you will have to install the driver for the LPT addon card and then your software.
