Question about Samsung Audio Players & Recorders
I want to program my Toshiba 90275 remote control to my Samsung HT D 8600 home theater system
SOURCE:
techman
  • 3130 Answers
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
Posted on Oct 15, 2007
ANTHONYPAULB
  • 17 Answers
SOURCE: Samsung program codes for ht-q100 Remote
You can try any of these 006, 011, 014, 015, 019, 027, 036, 037, 077
Hope this helps..
Posted on Nov 30, 2007
szwaan
  • 209 Answers
SOURCE: remote control or universal remote that works on my durabrand home theater system 2004 model # HT 3915
The easiest thing to do would be to go to an electronics store, look on the back of the remote control package and look for Durabrand.
It should come with a booklet with the setup codes.
Thats all I got for now.
Hope that helped, good lukc, please rate.
Posted on May 10, 2008
SOURCE: comcast remote and need code for a samsung ht-tq85 home theater
http://www.ehow.com/how_2116903_easily-program-comcast-remote-control.html
Posted on Aug 02, 2008
My remote is bad and need to increase the volume manually on Samsung ht-txq120 home theatre system
If your remote won't work at all, then you'll need to get a new remote from Samsung to control all functions. If however, everything works on the remote but the volume, keep the original for all other functions and just use a cheap universal remote programmed to the Samsung code to control the volume. I had the same thing happen on a Sony THIB remote for a HT. I used a Scientific Atlanta to turn it on and off, as well as control the volume, but retained the original remote so I could get at all other functions. If you have to buy a new Samsung remote or if you buy one of those high-dollar universal remotes that program a zillion functions it will cost you big. Fair warning.
Mar 17, 2016 | Samsung HT-TXQ120 Home Theater System...
Ah59 02291a remote wont connect to anything?
If your remote is a Samsung, it should be able to connect to your Samsung HT-C450. Although you say it has batteries in it, those batteries may be no good and fresh ones are needed. You need to determine whether your remote can be programmed to control your Toshiba TV. Instructions for using your remote could be useful for solving this problem.
May 12, 2014 | Samsung Audio Players & Recorders
Remote control code for Samsung Home Theater System HT-EM35
Better to look for an original remote, a universal if this will even program will be missing key needed features.
Nov 03, 2012 | Samsung HT-EM35 5.1 CH Home Theater System...
I need the remote codes for a Samsung AH59-02291A
The Samsung AH59-02291A remote came with several Samsung Home Theater systems, including the HT-H4530 and the HT-H5500W. The remote is not a universal remote and will not control other devices. You can learn a bit more about the remote by looking at the manual for the home theater system that it came with. The HT-H5500W manual is available on that product support page: https://www.samsung.com/us/support/owners/product/2014-5-1-channel-blu-ray-home-theater-system-ht-h5500w. If you need a universal remote to control the home theater system, look for one manufactured and programmed after 2014 for the 2014 HT-H5500W.
I hope this helps.
Feb 02, 2011 | Samsung Remote Control Remote Control
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
Comcast remote and need code for a samsung ht-tq85 home theater
May 17, 2008 | Televison & Video
I can't program my home theater to my universal remote
logitech remote will be only one to control it best to use orginal remote with it has all nice fetures in audio ect
Jan 23, 2008 | Samsung HT-Q100 System
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
