Heating & Cooling Logo
Dustin Christensen Posted on Dec 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the wiring diagram for the Lakewood heater QTV-22
john h
Level 3:
Top Expert:
  • Lakewood Master 29,494 Answers
  • Posted on Dec 13, 2018
john h
Lakewood Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7547016
Points
193449
3 Related Answers
Anonymous
  • 1489 Answers
  • Posted on Apr 29, 2009
SOURCE: Cycles on and off after reaching desired temperature
The problem sounds like the thermostat which is probably a bimetal strip. It sounds like the bimetal strip is just constantly bending one direction then the other. It could be possibly adjusted by bending it -- this would be a trial and error process.
Or, it could be replaced.
Anonymous
  • Posted on Jan 01, 2010
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Bill Boyd
  • 53816 Answers
  • Posted on Oct 29, 2017
SOURCE: I have a Lakewood QTV-22 750/1500 Watt heater and one of the tubes doesn't heat up when I turned it on. Is it safe to use?
yes
as the elements are in parallel
have an appliance shop replace the faulty element
I need wiring diagram for a Lakewood heater
try this link.
https://images.app.goo.gl/eqouF5WZLpQbu987
There are several diagrams for lakewood heaters.
Youb can also do a search google by typing in (wiring diagram for a Lakewood heater).
I painted my Lakewood Quartz heater Model QTV - 22 but cannot remember how to re-connect the wiring don't want to short out the heater! I need a wiring diagram
Is it 120 volts or 220 ?.
If 120 then connect the black or red to power and white to nuetrual.
220 is 2 hot and a ground
Are you telling I can't get a wiring diagram for LAKQTV-22 heater.
Hello -
I have looked for a wiring diagram for your heater. I even checked the web site of the manuafacturer, Lakewood Engineering & Manufacturing Co., Chicago, Illinois with no luck.
In fact, it seems the company no longer manufactures any heaters.
1helpful
I need a wiring diagram for a lakewood 5500
Visit this page for service center info and or parts: they should be able to help you http://www.lakewoodeng.com/html/parts.html
Top Lakewood Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Paul Carew
Jay Finke
Jay Finke
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
