It is a Coleman model5010000320 I have lost the manual Tracy
SOURCE: Panasonic Microwave Fuse Replacement
Is it like this?
If so, there are several ways to loosen them:
Some folks just use a hammer to tap and loosen the screw, then a "star", t-type, or small flathead screwdriver can be used to remove the screw.
Sometimes the screws are tough, so you may only be able to just bend the post slightly with a punch, then a small flat blade will "grab" enough to turn the screw. Pliers on the handle will help, too.
Another creative solution is to use a hacksaw or a Dremel tool to carefully cut a slot in the head so a flatblade will fit it, as shown in the photo below:
SOURCE: How do I remove the manual window winder handle ?
I have to do the same with my door handle on my excel. The Window winder is held on by a sort of circlip thingy and they do make a special tool to remove it, and i would reccommend buying it or even borrowing one from a local mechanic. it is possible to remove it with a screwdriver and some wire but it is very hard and fiddly as you have to do it blind.
SOURCE: trying to find replacement bulbs for our Swissgear
You can find the bulbs you need at this link; http://www.bulbs.com/eSpec.aspx?ID=14393&Ref=Light+Bulbs%2c+Ballasts%2c+Fixtures+and+More&RefId=0
SOURCE: Coleman rechargeable lantern: Charged overnight -
Check the battery with a volt meter to make sure you have the correct voltage. If not, replace battery. If correct voltage, bypass switch to determine if it is good or not. If not, replace. There really isn't much to go wrong on the lanterns except the bulb or battery.
SOURCE: Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
