Question about Hitachi Televison & Video
Hitachi LE55A6R9A. Basically, there was a power outage and it worked for the next day or so then it only emitted audio but no picture.
I went and bought a T-Con board and after installing it there was no luck. My next step was going to be to buy the Power Supply Board. Is this the right move? check input or source
SOURCE:
SOURCE: new lamp turns on flashes 7 times
just replaced lamp and power light goes green then orange and starts to blink 3 times
Posted on Oct 21, 2009
jdvillanueva
  • 2098 Answers
SOURCE: Hitachi 57f500a e907 fuse blew on the power supply
If QH01 is shorted again, then this is an indication that the FBT is already faulty causing QH01 to shorts right away and blew E907(self destruct when shorts occured on the line). 100VDC isn't causing E907 to blew, you've only got 100VDC because the FBT didn't oscillate yet. Before you replaced the FBT make sure to test all parts parallel on the B+ line like DH09, Q701, CH16, CH13, CH20. It is better to pull-out the FBT while testing the shorted/leaky parts on the board to make your reading more accurate. If you found the said parts to be in good condition, then you have to replaced the FBT.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Nov 04, 2011
bronk50
  • 27725 Answers
SOURCE: powersupply went out replaced power supply on my DX4300 powers on but no picture on moniter
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause you problems
computers need all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Posted on Jun 19, 2012
gopakumarg43
  • 76036 Answers
SOURCE: won't switch on
You reports that you've changed the T'Con board. Where is the T'Con board to a Plasma TV? There is no such board to any plasmas. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
Posted on Dec 04, 2012
gopakumarg43
  • 76036 Answers
SOURCE: Replaced main power board and t con board. Picture now works, but horizontal white lines moving upward.
Sounds like fault with its main power supply bard too. Check all the wiring connections from the main board to SMPS board for any loose connection. Improper wiring too can cause this fault, due to AC line interference. Check these well, before replace the SMPS [power supply] board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Jul 25, 2015
Hitachi LE55A6R9 / LE55A6R9A need a back-light inverter, Which one do I have to order?
Contact the authorized service center for Hitachi, to get more details.
Apr 06, 2018 | Hitachi Televison & Video
Hitachi LE55A6R9A audio no picture(can hold light near screen and see picture)
Test LED output voltage, if its missing look at the power board as being bad, also test the PWM voltage and make sure its between 2 and 4 volts, if its not correct the main board may be bad.
Jan 06, 2018 | Hitachi Televison & Video
Hitachi TV 55inch LE55A6R9A doesn't have picture or audio but has power.
Main digital board fault. Check and replace it. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 01, 2017 | Hitachi Televison & Video
My tv clicks to come on but no sound no picture
If there was a power outage the problem is likely in the power supply.
The power light on the front comes on or not?
If no power light unplug the set and follow power cord inside and check the fuses---the click is a power relay activating---set may have up to 3 black relays on the power board.
Let me know your skill level and I will be happy to help.
SD TECH
Jan 16, 2012 | Hitachi 57F500 57" Rear Projection...
Power outage.. volume not as loud as before..part bad??
Yes the audio board is going bad there is a capcitor on that and it would need to be replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 21, 2009 | Hitachi 51F510 51" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
