SOURCE: IT SHOWS ME THIS ERROR CODE C610 WHEN I SWITCH IT ON.
You have blown your thermal fuse, causing an open circuit.
You have to remove the fuser and remove the thermal fuse. It is very easy to get it, it looks like a round black stump with a shiny bottom with 2 space terminals at each end, the bracket should be white, you cant miss it.
remove the thermistor and throw it hard on the concrete outside, you will not break it, what you are looking for is to make it rattle again, once it rattles again, re-install.. and clear the error code..
To do this you will have to do the following;
Press 'stop/reset' then 'start' then left copy exposure button and hold them all down. This will enter simulation/tech mode.
Enter '163' you do this by pressing the + and - buttons (zoom buttons)
'CLE' should show up (Clear)
then press start.
Reboot the machine and you away again.
SOURCE: stacker full error
No, what is happening on top of the printer (output tray). There is a little black tab that pokes down, when that is out of position or the output tray is full. To fix this first remove all the paper on the top and move that black tab, so it points straight down. This should fix this error.
SOURCE: MB 480 OKI Printer Error Codes
you can some error code at manual
if you did not have manual you can download amanual at
http://www.german-parts.de/oki_manual/paperjam/stau_mb400_series.pdf
at that manual you can find some error code and how to fix it
For the 3,000-sheet stacker or 3,000-sheet stacker/stapler, the output bins are the upper bin (face-up) and the lower bin (face-down).
The upper bin (face-up) is the top bin on the stacker or stacker/stapler. This bin holds up to 100 sheets of paper in face-up order as they exit the printer. A sensor causes the product to stop when the bin is full. Product operation continues when you empty or reduce the amount of paper in the bin.
Lower bin (face-down) is the lower bin on the stacker or stacker/stapler. This bin holds up to 500 sheets of paper and can stack or staple jobs. This bin is the default output bin.
Replace the RFID R/W board.
