Question about Sony Computers & Internet
Need colour code for conecter to Sony VBC-RV-2MH camera cable to monitor have different colours to pins
SOURCE:
noone
  • 105 Answers
SOURCE: two vertical lines across screen
This is a common problem when LCDs are subjected to strong shock. Your internal circuits are damaged The panel itself may not be cracked but there is internal damage. I know of no cure or repair possible other than to replace the panel assembly.
Posted on Sep 24, 2006
SOURCE: Wiring colour code
Please call 1-877-392-7247
Posted on Jan 07, 2008
SOURCE: screen keeps changing to different colours when i switch pc on
video output lose contuct or CRT base lose
Posted on Feb 25, 2008
SOURCE: wire a vga cable in backin
in vga connector their are 15 pins .u have to solve this problem u have a digital meter to cheack contunity of the pins. if there is old wire is connected on crt board .first u cheack 0 omhs continutey to 1 pin to 15th pin. then u sold ur new cable
Posted on Mar 05, 2008
SOURCE: VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Posted on Dec 24, 2008
Need a link for the directions on how to connect cables to the computer. serial #105255894
Connections
> Blue 15 pin or white 16 pin colour port is for monitor.
> 3 pin female port is for power cable for Computer Tower
>3 pin male power cable is for monitor
> Purple and green colour port is for Keyboard and mouse if they are ps2 (round connector) if usb then connect in any usb port.
>Small 3 colour ports Pink,Green,Blue is for sound.Connect only the Green colour cable coming from speaker to green port
>Connect the speaker Adapter cable to the wall socket for supplying power to speakers.
> RJ45 (Ehternet port-port which looks like phone connector but little bigger will connect Internet cable if you have internet.
Connect and Enjoy
Sep 08, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
My monitor resolution colour is changed to pink.
Check the data-cable between the computer and the monitor, and try a different cable.
Or, try connecting the monitor to a different computer, to see if the video-card in your computer is not working correctly.
If necessary, replace the video-card.
Colours on your monitor are produced by "mixing" the 3 "primary" colours: red/green/blue in various proportions.
Or, if part of the monitor that produces one of those 3 primary colours has stopped working, then the resulting "mix" will have too much RED/PINK. Fix/replace the monitor.
May 29, 2010 | SAMTRON 55V 15" CRT Monitor
My whole screen has a blueish green tint
  • Make sure the plugs are hard into the sockets, one loose pin can cause strange colour problems.
  • A faulty signal cable between PC and monitor can also cause colour problems, try a different cable if possible
  • Try it on a different computer to find out whether the computer or the monitor is the problem. If it's the monitor and none of the above works, it will need service or replacement. If it's the computer, your video card is likely to be the problem.
Apr 09, 2010 | Samsung Syncmaster 940BW LCD Monitor
Monitor changed to yellow colour.... what is the problem...?
Monitors mix the 3 "primary" colours, in various proportions, to produce all other colours.
Mix equal parts of all 3 colours, and you get WHITE.
Mix equal parts of only 2 colours, and you get YELLOW.
So, either:
1. your computer's video-card is not sending the 3rd colour;
2. your video-cable between the computer and the monitor is broken, and is not transmitting the 3rd colour;
3. your video-cable is not TIGHTLY connected at each end;
4. the electronics inside the monitor that SHOULD be producing the 3rd colour have failed.
Try connecting the monitor to a different computer, with the same video-cable. If it works correctly, your video-card is the problem.
Try connecting the monitor with a different video-cable, to see if replacing the cable fixes the problem.
Try connecting the monitor to a different computer, with a different video-cable. If it still is incorrect, then the monitor needs repair/replacement.
Jan 14, 2010 | Computers & Internet
My omnitech monitor is turning red when it wants to. no certain program just whenever
Colours on the screen are generated by "mixing" the 3 primary colours.
Of the primary colours is RED.
So, your LCD monitor is not receiving signals from your computer,
specifying the other two primary colours.
Check the data-cable between your computer and your monitor,
to ensure that the connections are tight at both ends.
Try a different data-cable.
Try your monitor on a different computer, with two different data-cables.
Try a different monitor on your computer.
It could be the video-card inside your computer is failing to "send" one or two of the primary colours.
Dec 31, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
Colour problem
This is a problem that is associated with some electronic components inside your monitor. Also it can happen if some of the pins on monitor's data cable (that connects to CPU) are bad or the cable itself is bad. Anyway you have to go to an monitor repairing shop.
Jan 01, 2009 | LG Studioworks 700S 17" CRT Monitor
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
4&5 Not connected
9&10 NC
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Sony pfm42x1 colour problem
Check the settings in the menu and make sure you have the input properly set to RGB and not color difference settings (Y, RY, BY).
Apr 22, 2008 | Sony PFM-42X1 Plasma TV
Computers & Internet Logo
42 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
