SOURCE: telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
dial tone but mobiles ahve no dial tone when making or receiving calls.....
SOURCE: I pick the phone up, no dial tone. Display says
We called the phone company.....There was a problem up on the telephone pole. They fixed it, no charge.
SOURCE: No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
SOURCE: no dial tone and "line in use " message
Try the simple things first. Try a different phone. In my case, I had the phone company check - outside was fine. After two hours my phone worked. I figured out what happened in my case. Both phones were dead (battery). I think one died with the phone off the hook. once the phones were fully charged, the phone worked.
I cannot hear a dial tone.
The telephone line cord is connected to the [EXT] jack on the unit. Connect to the [LINE] jack (page 21).
L If you use a splitter/coupler to connect the unit, remove the splitter/coupler and connect the unit to the wall jack directly. If the unit operates properly, check the splitter/coupler.
L Disconnect the unit from the telephone line and connect a known working telephone. If the working telephone operates properly, contact our service personnel to have the unit repaired. If the
working telephone does not operate properly, contact your telephone company.
L The power cord or telephone line cord is not connected. Check the connections.
L If you connected the unit through a computer modem, connect the unit directly to a telephone line jack.
I cannot make calls. L The dialing mode setting may be wrong. Change the setting (feature #120 on page 22).
The unit does not ring. L The ringer volume is turned OFF. Adjust it (page 23).
Hope this is helpful. ;)
