When the actors talk the words come out hard to understand
SOURCE: My send is fuzzy and hard to understand. I recieve just fine
Perhaps you need to check your SWR? See the following link: http://www.transmission1.co.uk/modules.php?op=modload&name=News&file=article&sid=11
SOURCE: when i watch dvds,the background noise is loud
Go to your set up menu, navigate to speaker set up and check your sound levels to front, center, and rear channels. Adjust as needed to fit the room. My Sony has a test tone option which sends a signal (at levels selected) to each speaker to check sound level and if speaker is connected and in right place.
SOURCE: Lousy sound on 32" Sony Bravia
if you are have problems with in built speaker when the tv speakers are on, then connect on audio out hi fi
audio out. and make sure your speakers are on off.
SOURCE: When I am playing music on my speakers....you can
The speakers are defective. They will need to be replaced.
SOURCE: When I am playing my
1. check the power supply to the speakers. and also the cable of the speakers. there could be a short somewhere.
If that does not help, give me the following information:
Are these speakers new or old?
if old, try opening up and cleaning them. unplug them first though...
