SOURCE: Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
SOURCE: gas fireplace will not stay lit
there is a probe that is in the one of the flame... This once heated builds up enough pressure do to the heat to keep the shut/off valve open... (reason, if the flame went out the gas would continue to flow) this "thermocouple is replaceable !! contact me at [email protected]
SOURCE: Montigo fireplace model M38DV-PFC Pilot light
the thermal coupler is bad . that is the tube with the brass line going to the gas valve. and sets at the pilot.
SOURCE: gas fireplace pilot light won't stay light or
The first thing to change would be the Thermo-coupler
