Washing Machines Logo
Frances Harriman Posted on Dec 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My machine keeps turning itself off and then back on.
Dave Yale
Level 2:
Habit-Forming:
New Friend:
  • Expert 60 Answers
  • Posted on Dec 25, 2018
Dave Yale
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
60
Questions
0
Helped
47698
Points
160
1. The washing machine may shut off unexpectedly if the water supply is slowed.
2. Also some new models may stop automatically if sense that there are too many suds in the washing machine tub.
3. And of course, the most common reason - the washing machine may stop unexpectedly if the motor overheats in order to protect the motor from serious or permanent damage.
Chris Huff
Level 3:
Top Expert:
  • Washing Mach... Master 6,289 Answers
  • Posted on Dec 11, 2018
Chris Huff
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2018828
Points
74913
Motor may be overheating
My keurig turns itself ON... Keurig tells me it has nothing to do with the recall they have going on now.
I am afraid I have no idea on these machines though I had a quick look on their website to read an instruction book on a couple, as a former service engineer and a bit long in the tooth I have never liked items that can turn on alone, but times change.
Well two things strike me one is you can set a time for it to come on in its settings, or locate the system reset default also in its menu.
This will wipe out any other settings made but will bring it back to a start point, if after that it still wants to turn on it would need a repair before any other problems arise.
Hope this helps.....
Ar M55on Keeps turning itself off and on
Machine is trying to load toner .just let it continue until it gives
an error code otherwise ..
Janome sewing machine dial moves
I have exactly the same problem. Did you find a solution? If so I'd be really grateful to hear it ... Thank you.
I changed the ink but the machine keeps turning off. I put the old ink back and then I tried to print again, it keeps coming up error. I have reinstalled the printer and restart my computer but it keeps...
For safety, this machine will power itself off if there is a fuser heat control issue. The fuser is AC and the power off is a safety feature to prevent a fire. Take the printer to a qualified repair facility.
1helpful
Machine turns on and off by itself and keeps doing it
Hubby says it could be a stuck button. Otherwise there could be a fault with your front control panel. Feel special, he's never come across that before!
2helpful
My almost new Keurig (which I LOVE) keeps shutting down
I am having the same problem and will report back here if I find an answer. If I keep turning mine back on, wait for it to go off by itself. Turn it back on again...and again. Eventually I can get a cup of coffee. But my one-minute coffee cup usually takes 15 or 20 minutes.
Mine was a gift, so I'll probably just see if I can swap it out.
Cuz that's some good coffee.
Fisher & paykel - SPIN light keeps flashing and machine beeps
could be a faulty off load switch
running off balance
machine not level
depends how old the machine is then
if none of those
worn machine motor or internals
might the the circuit board
Fisher&Paykel Smart Drive 051 keeps beeping/not draining
Hi, I have the same problem and for my wahsing machine it is block pump, so I turn the machine on and advance it to spin and turn the pump fan to help clear the block, the pump locate at the buttom of the basket of the machine...
Phone keeps turning on the answering machine all by itself.
figure out how many times it takes for your phones answering machine to automatically turn on, then call your phone company and have them limit the number of times your phone rings. like say at 14 rings if it auto answers at 15 rings.
Computer freezes, No Keyboard No mouse, but machine keeps on running
Try to check the capacitors of the motherboard, maybe some of them are damage, they can cause this kind of problem
Top Washing Machines Experts
john h
