Question about Maytag Dishwashers
Where is the thermal fuse located in Maytag mdb4949sdm dishwasher?
    Top Expert:
  • Maytag Master
  • 6,289 Answers
Under the unit. It’s a 1/2 inch round disk with 2 wires going to it.
Posted on Dec 11, 2018
SOURCE:
SOURCE: thermal fuse location
where located fuse
Posted on Sep 17, 2008
kachbibi1
  • 979 Answers
SOURCE: where in Thermal fuse located maytag model #PYE2300AYW
Take the top off the dryer and you should find it located at or near the drum.
Posted on Jan 17, 2009
  • 492 Answers
SOURCE: where is the thermal fuse located?
In the back of the dryer. Look for the coiled heaters and follow the lead wires back to the fuse.
Posted on Apr 30, 2009
jsrock516
  • 5911 Answers
SOURCE: Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Posted on Jan 06, 2010
Testimonial: "Excellent info. Thermal fuse was out of sight. Mention about LA-1053 helped. Honestly, I didn't know how thermal fuse looked like."
SOURCE: Maytag Neptune Thermal Fuse Location?
Yes, I just changed thermal fuse on the same model . . . take off the front door, the front panel and there it is; attached to the vent tube with a flimsy bracket
Posted on Oct 08, 2010
How to turn off lock light on panel for model MDB4949SDM
To toggle the Control Lock, press and hold the Sanitize button for 3+ seconds (until the LED goes off). When you toggle the lock on, the LED will flash three times. See page 5 of the Owner's Manual for information on the control lock. If you look below the Sanitize button, you will see in a small font "control lock hold 3 sec." to help you find the appropriate button on a different model.
The manual for the Maytag MDB4949SDM is available on the product page: https://www.maytag.com/kitchen/dishwashers-and-compactors/dishwashers/front-control-dishwashers/p.stainless-steel-tub-dishwasher-with-large-capacity.mdb4949sdm.html . Scroll down to the Specifications section or use the Specs & Manuals link. The direct link to the manual is currently https://www.maytag.com/content/dam/global/documents/201802/userguide-w10832285-revb-eco.pdf .
I hope this helps.
Sep 11, 2018 | Washing Machines
Control panel not working. Where is thermal fuse located?
Go to www.repairclinic.com and enter MDB5601AWS. You may get a clue as to where to find it. You also will get an illustrated list of common replacement parts which will aid further identification.
Feb 09, 2016 | Maytag 24 in. MDB5601AWS Stainless Steel...
Where is the fusible link for my LG dishwasher?
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Sep 07, 2014 | LG LDS4821ST Stainless Steel 24 in....
MDB7130AWB thermal fuse
This might help. This is the thermal fuse you need if you need a replacement. Cost is somewhere around $25.00
Thermal Fuse
PartSelect Number PS342838
This part is used as a safety device to protect the dishwasher circuit from overload. If the temperature gets to high it will shut off the electrical current to the heating unit in the appliance.
This part works with the following brands: Whirlpool, Admiral, Estate, Inglis, Kenmore, KitchenAid, Roper, Maytag, Kenmore, Admiral, Crosley, Jenn-Air, Hardwick, Magic Chef, Amana, Caloric & Glenwood.
This part fixes the following symptoms:
  • Not drying dishes
  • Will not start
See part 26 in the diagram
Apr 08, 2013 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Dishwasher mdbtt60aww1
sounds like it is the thermal fuse, located on the main control board. it will have 2 wires connected to it,a black and a black w/white stripe, pull one wire loose and check for continuity. if it is open replace it. should work fine.
Jan 07, 2012 | Dishwashers
My dishwasher just quit during the cycle but it still has power going to it none of the lights on the door will work now and it wont restart
There is a thermal fuse located in the control panel that is probably blown out.
Open the control panel by removing the 6 screws around the top inside of the door. The thermal fuse is located on the top right side. Remove the wires from the fuse. Use a volt neter set for continuity to test the fuse. No reading is a bad fuse.
This link will show the fuse.
http://www.appliancepartspros.com/part_details.aspx?part_id=3115186&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5162747%26diagram_id%3d914101
Jan 03, 2010 | Maytag MDB4621AW Built-in Dishwasher
Mdbh940aws - maytag dishwasher not woking
It might be a thermal fuse. Check this thread:
http://www.fixya.com/support/t545481-dishwasher_panel_no_power
May 30, 2009 | Maytag 24 in. MDBH940AWS Built-in...
Where is the thermal fuse located?
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Dishwashers Logo
147 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
