Question about Maytag Dishwashers
Maytag jetclean dishwasher - quiet pack - Maytag Dishwashers
6ya staff
SOURCE:
Dov Dror
  • 641 Answers
SOURCE: dishwasher options
You should buy a dishwasher salt (don't put in cooking salt !!!!!) The dishwasher salt is a particular grade of crystalline sodium chloride intended for use in dishwashers.
Posted on Sep 16, 2007
Michael Anderson
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
Val Barker
SOURCE: Maytag jetclean EQ plus dishwasher
I had the exact same problem. When the service tech came to look, my husband watched him. There was a disconnected wire to the motherboard which my husband asked can't the tech just reconnect it. The tech stated no, we needed a new motherboard. My husband reconnected the wire using tape for now & the dishwasher is working perfect. My husband is going to get somekind of calk/glue that will work permanently. This should save us from replacing the motherboard for a while. The dishwasher is only about 5 years old! My previous dishwasher was over 20 years old with no repair problems the over 10 years that I owned & used it.
I am looking for the self check test, does anyone know where I can find the instructions how to do it myself? Thank you
Posted on Jan 12, 2009
Anonymous
SOURCE: Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Posted on Apr 06, 2009
Bob Groh
SOURCE: Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Posted on Jul 15, 2009
Users manual showing how to operate maytag jet clean dishwasher quiet plus
Good Morning Marion!
You can find installation and user guides for the Maytag Jetclean here
Maytag Jetclean Dishwasher (it's the Maytag site, and the page has several links to PDF files. The specific owners manual is at
http://www.maytag.com/digitalassets/MDB5000AWB/Use%20and%20Care_EN.pdf
Hope this helps, and good luck!
D
Nov 19, 2015 | Maytag Dishwashers
My maytag dishwasher jetclean quiet pack won't drain
Hi Cherie: Try watching this video that demonstrates how to repair non-draining dishwashers: https://www.youtube.com/watch?v=rO19zoOyNHA
Apr 18, 2015 | Maytag Dishwashers
My maytag jetclean dishwasher quiet pack makes a grinding noise and the sprayer doesnt spin
Take apart the sump filter area and check to see if anything is stuck in the impellers for the wash motor.
Jan 01, 2015 | Maytag Dishwashers
On a maytag jetclean quiet pack dishwasher all the panel lights come on and flash
I had the same problem today - they replaced my telephone pole yesterday and had the power shut off for a couple hours. All light blinked when door closed. I reset by pressing the "drain/off" button for 15 seconds.(found info. on another site) Seems to be ok now
May 21, 2012 | Maytag MDB7100AWB Dishwasher
Dishes are`t clean ,arms dont spin during wash cycle
what is the model # how mutch water is in the basin?
Jun 28, 2009 | Dishwashers
Loud noise during cycle MDB6600AWB Maytag Quiet Series II
look for odjects in the pump cutter ie glass plastic or the cutter is bent or a rushing sound could be motor bearings
Dec 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag dishwasher latch
If it like mine, the latch is out of adjustment and you need to give it a whack with your hip to start it. If I adjust the latch looser, it leaks.
Oct 24, 2007 | Maytag 24 in. MDB8600AW Jetclean II...
Jet dry not draining no clog as far as i know
i needed all your all your serial num its important 17
Nov 30, 2006 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
158 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
