1994 Volvo 940 Logo
Posted on Aug 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blue smoke out of exhaust, replaced turbo, still smokes a lot when engine revs
Marvin
Level 3:
Top Expert:
  • Volvo Master 85,242 Answers
  • Posted on Aug 04, 2009
Marvin
Volvo Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29056394
Points
266281
Have you driven it at least 100 miles since repair?, the oil residue builds up inside the exhaust and burns off very slowly from the previous failed turbo seal.
2answers
Hi, i recently replaced the turbo charger for our VW passat. However there is thick white smoke coming out of the exhaust.
the turbo your mechanic put on was 2nd hand and knackered i expect ,,,,white smoke means turbo still gone ,,,,
I changed the turbo now white smoke coming out of my exhaust
This seems to be a symptom of a blown head gasket.
White exhaust smoke is an indication of water / coolant in the exhaust. The car running sluggish and using lots of fuel can be caused by compression loss.
Look at the coolant level color and smell (with cold engine - don't open the high pressure reservoir with engine hot as hot coolant may spray you in the face). If you have a blown gasket, the coolant color may become brownish and it may smell bad or the level will get lower even if you have just refilled the cooling system.
What you can also check for is bubbles in the reservoir. With engine cold, remove the reservoir cap. Start the engine. Try to rev the engine (or have someone do it) and observe if there are bubbles in the reservoir tank. If you see lots of bubbles, you have a blown gasket.
1helpful
How to recognize if my turbo is causing blue smoke from the exhaust vs a blown head gasket. I don't have anti freeze mixed with my oil but it smoke coming out the exhaust when the car is running. ...
It's very simply to find out if the turbocharger is causing blue smoke from the exhaust vs a blown head gasket. So, remove the turbocharger's compressor inlet centre hose (from the aluminium side of the turbo). Then see if there's in plenty of oil coming out from the hose and from the turbo. I'm 100% convinced that the turbocharger is damaged in your case. You can remove also the exhaust pipe out from the turbocharger, and see if there's a lot of oil coming out.
Repair or replace bad turbocharger with a new one (or with a second hand in good condition one). Good Luck!
5helpful
2answers
Exhaust smoke definitely not steam. Someone opined that it may be related to the turbo/exhaust system. What do you think?
A worn turbo or broken would create smoke. Blue or Gray smoke is either worn rings or a clogged PCV. White smoke is from foreign fluid entering the engine. Typically indicative of a head gasket leak. Black smoke is Leaking injectors or an ignition problem or an issue with the turbo.
If you are experiencing a loss in power then you most likely have a worn turbo bearing.
1helpful
2answers
BLUE SMOKE FROM AUDI RS6 ON DE ACCELERATION AND START UP THINK OIL STEM SEALS ARE LETTING OIL THROUGH. CAR RUNS FINE I THINK, AND EXCESSIVE BUILD UP OF OIL IN DRIVER SIDE TURBO PIPE, 62000 MILES WITH A...
General rules of thumb: Low speed engine on acceleration with smoke in the exhaust plume = worn piston rings High speed engine accelerating (spooled up turbo) with smoke = oil form turbo bearing and/or piston rings Engine on over run (coasting down, foot off the gas) with smoke = oil from valve guides. VW/Audi make good engines with tight tolerances so none of the above should apply at 62K miles; just make sure that the oil (the right oil) and oil filter are changed regularly.
X5 diesal blue smoke
Hi , if you have had a turbo failure on this vehicle , just replacing the turbo will not cure the cause of blue smoke . depending how bad the seals had gone in the turbo you would need to replace , the complete exhaust system , the crankcase breater , air intake manifold , air charger but only if these items have been contaminated with oil , they would not be able to be cleaned out , hope this helps , regards mark
9helpful
2answers
White smoke from exhaust
If you are getting clouds of white smoke out the exhaust it is a good indicator of antifreeze getting into one or more of the cylinders. I bought a "Great" car sight unseen from a friend once and when he pulled in the drive the whole car disappeared in a cloud of white smoke that only left when he shut the engine off. I found head gasket leaks in half the cylinders. It takes very little coolant to cause the white smoke. If you are absolutely sure of zero coolant loss perhaps the smoke is a little blue--an indication of burning a little oil from a sloppy turbo bearing. Try the nose test-- it may give you the answer. Burning oil has a distinctive smell.
Turbo leaking oil
turbo oil seals will cause a lot of smoking .
2answers
Thick white smoke coming from exhaust
White smoke usually associated with water or moisture. it doesn't take too much water to produce white smoke. check
1. cloudy oil under oil cap
2. leak through gasket from cooling jacket to combustion chamber
7helpful
5answers
Blue smoke coming from exhaust
blue smoke out of 1.8 turbo its allways bad oil seal inside turbo.need new turbo or rebuild OEM. with 24 years experience working with vw never seen single headhasket go bad on 1.8 turbo engines.blue smoke its 100% turbo every time
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
