My whirlpool dishwasher gold GU2475XTVQ0 had rapid blinking lights that started with the "4 Hour Delay" LED and changed to others when other buttons were pressed. The machine would not run. I followed the instructions located behind the kick panel and verified the keypad was the issue and not the control circuit by elimination.
The big surprise for me was that when I used a straight pin to resistance check all of the buttons, they checked out OK. I reconnected the 14 pin connector (P1) to the control and found that the buttons/LEDs were behaving correctly! I believe that pushing the straight pin into the 14 pin connector removed any corrosion in the 10 year old device and permitted the keypad to communicate with the control again.
I reassembled the dishwasher door and it ran with no problems. I was ready to replace the keypad for $150, but didn't have to!
SOURCE: Dishwasher's "Pot-n-Pans" light flashing
ga, behind the toe panel on the bottom there should be a tech sheet explaining how to put the dishwasher in the test mode. See if you can enter the test mode. If you can't, you probably have a stuck or shorted keypad. Catriver...post back
SOURCE: Flashing pot and pan light
shut off the power and see if the unit will reset. if its plugged in, it will be easy, look under the sink. if not, try a breaker.
let the power stay off for about a minute.
then back on.
if not restored, then you have logic boards that failed.
sorry,
good luck
mark
SOURCE: Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
SOURCE: The only number on the nameplate of my
Yes, you almost certainly have a Whirlpool Gold Quiet Partner III Model #8575637
Of course the great news with buying from Costco is the ability to return products you are dissatisfied with. Check with the customer service desk.
Please reply if you want to to get into repairing it and we will get under way.
