Question about Frigidaire Washing Machines
Frigidaire front load washer GLTF2940FS starts, just fills and won't agitate or spin. Stops ~1 minute in when it decides to not work. Happens sporadically. Worked 2 nights ago, but not last night.
    Top Expert:
  • Frigidaire Master
  • 63,103 Answers
POSSIBLY THE CONTROL BOARD HAS FAILED CALL A SERVICE LOCAL TO YOU AND GET IT TESTED
Posted on Dec 13, 2018
SOURCE:
BADBOYJAY
  • 274 Answers
SOURCE: Same as many - Washer does not spin or agitate but everything else works fine
your brushes are gone you will have to wright down you model number and look on ebay there really cheap
Posted on Jan 07, 2008
  • 57 Answers
SOURCE: Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Posted on Feb 16, 2008
SkinWill
  • 148 Answers
SOURCE: frigidaire washer starts to fill then stops
Check the water level fill sensor. Some used to be pneumatic tubes connected to a sensor. Your washer may have a different type of sensor. It seems like it fills ant gets to a point where it expects the fill sensor to trip but instead just stops. Also re check ALL connections to main drive motor.
Also verify your mains power can handle the draw of the rated wattage. When it goes to engage the main drive motor it may not have enough current from the mains and simply stops.
Also check that the connection to the tumbler drum is not frozen.
Posted on May 02, 2008
  • 10 Answers
SOURCE: front load washer wont spin
I have a Frigidaire Affinity and the same thing happened to me. After looking on this website I found someone who told me to change the door latch assembly. I went to my local parts supplier and bought a new door latch assembly for $53. My husband replaced the door latch, and it works like new! The good news is the replacement part is better made than the original. The parts guy said he's never seen one fail a 2nd time. This is a cheap fix to a serious problem.
Posted on Jan 02, 2009
  • 396 Answers
SOURCE: Frigidaire GLTF2940FS...does not do a final spin/clothes wet
If water remains in the drum the unit will not go into the final spin.There may be a couple of reasons for your problem.
1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water.
2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. I believe the pump is about $60.00 and is accessible after removing the front panel under the door.
Posted on Sep 10, 2009
Model gltf2940fs clothes still wet only after the perma press cycle
Good Afternoon Friend,
I understand that your clothes are still wet in your Frigidaire washer, model# GLTF2940FS, but only after the perma press cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try the perma press cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire GLTF2940ES Front Load Washer
Not spinning
Its likely you need a new motor speed control board, its the most commonly replaced board in these washers.On this model its located underneath on the right or left wall.You can't really test this but try putting the washer in to the Spin and Rinse cycle, if it doesn't spin then that is most likely your trouble.I did a quick Google search and found this page for the part:http://www.appliancepartspros.com/frigidaire-control-board-134743500-ap3891780.html
Feb 19, 2013 | Frigidaire GLTF2940FS 3.5 Cu. Ft. Front...
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer won't agitate
hi Cinebar.
this is what i found from the internet so not sure if this will be off help to you.
There could be several reasons why your Frigidaire washer will not agitate, including problems with the power supply, the wash cycle or the way in which the appliance was loaded. It is a good idea to try to resolve the problem with your washer yourself first since unnecessary repair call-outs can potentially be expensive if your appliance is outside its warranty period. Troubleshooting your Frigidaire washing machine will take about 15 minutes.
Confirm the water shutoff valves are open. If your Frigidaire washer cannot draw water from the pipes, it will not fill or agitate. The shutoff valves are usually located behind the washing machine where the water pipes meet the wall. Allow the washing machine to cool down for 30 minutes. Frigidaire appliances automatically shut off if the motor starts to overheat. The cool-down period lasts for half an hour if the appliance has not been switched off manually.
Verify that the detergent draw is tightly closed. If the dispenser is left open, the washer will not start or agitate its load. Push the draw so it sits flush with the front of the washing machine.
Ensure that the washing machine door is closed. As with the detergent door, the appliance will not start if the door is left slightly open, to prevent water from spilling onto the floor. Push the door closed until it clicks, and try your load again.
Confirm that your Frigidaire dryer is set to a spin cycle. If your dryer is set to a soak cycle or is currently in the soak portion of a longer cycle, it will not spin or agitate the wash. Make sure the appliance is set to a spin load and try again.
Contact Frigidaire if problems continue. You may be entitled to free service if your washing machine is within its warranty period. See Resources for Frigidaire's contact information.
or read up more at this link.
Frigidaire washer won agitate Google Search
Dec 11, 2017 | Frigidaire GLWS1649A Top Load Washer
Washer will fill, drain, and run a complete cycle but will not agitate or spin
sounds like the motor control board is bad. you could test the motor to see if it ohms out ok, the diagram has the readings. The diagram should be on the side panel (inside the cabinet) on the lt side in a brown envelope.
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Jan 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
