Your cabs need rebuild, something is stuck in the carb or air line cracked
If you have rebuilt the carb check for carb gaskett leak that caused and let the air flow in
When to choke is on the air is block and prevent air flow but allowed small amount of air to keep the engine running
After your engine warmed up the heat in the compression burn much faster so you have to let air in by turn off the choke
Good luck
Hello first thing i would start with is check your idle screw it may be set to low if the choke linkage is sticking .first take your breather off so you can see the choke linkage look to see where the plate is positioned is it fully closed have somone try starting with out touching the gas pedal if it doesnt start slightly open the choke plate if it starts you need a choke adjustment check to see if its manuel linkage, vacuum operated,or electrical. if vacuum check lines for dry cracks or splits preventing choke operation if electrical you need to test the power wire at the choke also test for good ground if mechanical check adjustment screw for curb idle to see if its set to low.goodluck please rate
