SOURCE: Morphy Richards Astral RV fridge
The Guest Post of May '09 is very accurate. I have a problem with the glow igniter associated with the black button. I need a new igniter and wonder if anyone knows where I can get parts. My model is a 7307 Morphy Richards Astral Frig.
Mel Mashman
[email protected]
SOURCE: How to change microwave bulb
If
there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's
manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If
it's an over the range type, remove the vent grille across the top and
see if bulbs can be accessed there. There may be a panel on the bottom
covering the light(s), instead.
If not, chances are
you'll have to remove it from the wall, then remove the outer cover. If
so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
SOURCE: magic chef gas/electric rv fridge
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry [email protected]
SOURCE: Red and green light flashing and wont work
PROBABLY A SHORT IN THE BANKET ITSELF AND IT SHUTS OFF TO PREVENT SHOCK OR FIRE.
SOURCE: Morphy Richards AC925EYG Convection has stopped heating items
Same thing has happened to me. My brother in law seems to think it cant be fixed. Bought it Dec 2008 so no warranty.
Were you able to get anythihng out of morphy richards?
