HI. the power supply board has failed. There is a fuse(3amps) inside
the power supply unit. you will need to remove the cover from the power
supply to access this fuse. once inside the power supply, inspect the
fuse. if it is truly blown, replace it. if the fuse is not blown, this
will confirm a failed power supply unit. it should be replaced in this
case.
((Contact Nintendo for a repair ticket if the unit has failed))
