Question about Video Cameras
Cassette door doesn’t close when tape is inserted
SOURCE:
Kimi
  • 277 Answers
SOURCE: cassette door stuck closed
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Posted on Nov 03, 2005
  • 217 Answers
SOURCE: Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Sep 28, 2007
  • 1894 Answers
SOURCE: Cassette Compartment on my Canon MV800i will not close to play tape
hello
Posted on Mar 08, 2008
  • 34 Answers
SOURCE: Cassette door is not closing
Your loading motor is no longer working or your mechanism is out of alignment.
Posted on Sep 05, 2008
SOURCE: reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Posted on Oct 01, 2008
How do I fix the tape holder system on my camcorder? The door won't lock, and the cassette won't get inside the compartment.
hi,
is it close without a cassette ? if so the reel sensor in the cassette compartment may be faulty. if the head drum not rotates the cassette drive will not work correctly, if so please loosen the head drum with a plastic rod or some tools like that. do not put your finger in hence sometimes will jam your finger. remember don"t touch the scanning chip of the head.
Oct 26, 2015 | Panasonic Palmcorder PV-GS12 Mini DV...
I have a sony cassette deck tc fx44. If I try to insert a cassette am unable to close the door. The door closes just fine without a cassette
Sometimes the tape sensors or record sensor gets bent or out of place so the door wont shut. Look for something like that.
Mar 30, 2013 | Audio Players & Recorders
The door those not close when I put a cassette in it. I closes normaly without a tape. Does anybody know this problem ?
alot of cassette tape deck doors actually come off, they clip onto the inner door assembly, if the outer part isnt clipped on correctly, it may shut without a tape, but not with a tape inserted, try to see if the outer door is clipped on there correctly, jim d
May 07, 2011 | Audio Players & Recorders
My Sony DCR-TRV33 won't accept a cassette. It will close itself up without a cassette tape in place, but not while a cassette is inserted. I have tried several different tapes, so it is not the cassette.
Hi wnwatkins3,
Have the same problem here. Bought my TVR33 in 2003, and its still
a good cam with 1 megapixel. But since 1 month the tape won't load. I can insert any tape in the cassette, but it won't close. Without a tape it closes fine.
My only option is to send it to frsbenelux to fix it for a few hundred euros. Hoping to find a solution on the net, i will share with ya.
greetz Ed
Jun 29, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
My sony trv37 cassette door won't close.
If this condition only occurs with as cassette inserted to load this may indicate a condition where the cylinder which holds the video heads is not spinning up when requested by the system control microprocessor.
If the door will not latch closed with/or without a cassette inserted this can indicated a mis-timed condition of the tape loading mechanism.
Try closing the door without a cassette loaded whilst the unit is powered from its AC Adaptor - under certain conditions this may allow the mechanism to reset and may allow the door to then close.
I trust that this information is of assistance! RHN
Jan 02, 2010 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-TR64 cassette door won't close
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Dec 04, 2009 | Sony Handycam CCD-TR64 Camcorder
Inserted tape into the cassette and the door will not open so I can remove it and it will not play as inserted.
use a paper clip to release it. there is a tiny hole located close to the deck, insert the pin and it shuold open. the tape might be tangled...
Jul 02, 2009 | Audio Players & Recorders
Aug 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Video Cameras Logo
483 people viewed this question
Top Video Cameras Experts
Al Rush
Ekse
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
