It say error E 23
Dear Annie Laurie,
I sympathise with your problem - unfortunately you have posted your query in a forum dealing with video cameras, so, unless you intended to film the process of laundrifying your garments, choosing a different forum (and, indeed, giving more in-depth information concerning the machinery and the fault) might get a more useful response. BTW, I suppose you have checked the manual for that error code - and also that the door is closed ?
SOURCE: problems
kenmore dishwaher mod. 363.14482100 lower spray arm
wont operate on its cycle and dishes are staying soapy
after dishes done.
Press the "Power" button to turn off the washer. Unplug the washer from the power supply.
Wait several minutes. Plug the Oasis washer back into the power supply and press the "Power" button to turn on the washer.
Select the desired wash cycle and press "Start."
If you think the wash load is in a spin cycle of the wash cycle or rinse cycle place the machine in Spin Only cycle and see if it will complete.
Waht are your DIY skills? Do you want to try the repair/fix?.............Rich
