Welding Tools Logo
Alley Vanpelt Posted on Dec 10, 2018
Hobart 250ci overheating, works fine for awhile then overheat light comes on ,shut off turn on same thing maybe longer maybe shorter
MMYZF600R
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Jan 02, 2019
MMYZF600R
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
1343
Points
See what your duty cycle is suppose to be for that welder. It may have a internal fan that has stopped working to pull the heat out. Some have some don’t. If not add one and it may give you a little more time to weld
5 Related Answers
Anonymous
  • 3587 Answers
  • Posted on May 04, 2008
SOURCE: slow, overheating, shuts itself off
sounds like your internal fans are taking early retirement, from all the symptoms..like running a car with no oil, you don't want to run a dell desktop without internal cooling..need to replace that fan..not too hard, actually.
Anonymous
  • 2920 Answers
  • Posted on Dec 07, 2008
SOURCE: LG projection TV model 52SZ8D-UA sound go on and off
your audio board is going out take it to a shop and have it fixed
Anonymous
  • 125 Answers
  • Posted on Feb 21, 2009
SOURCE: Imperial deep fryer IFS40 pilot lights, turn on
Hi there, it sounds like your thermopile, for the pilot, is failing during use, when this happens, the small DC voltage it generates is less than the gas valve requires to stay open, and shuts off the pilot, which shuts off the main burners. Another thing that could be happening, is the hi limit is opening prematurely, instead of shutting of the pilot at 450 deg. it now is opening at 325, or 225 or 250. Sometimes the sensing bulb gets broken where it pass's through the oil tank causing this symptom. If you temporarily bypassed the hi limit to test this also, and it still goes off, you need a thermopile. If it stays on, check your temp with a reliable thermometer, and see if it reads fairly close to your setting, if so, then you need a hi limit.
Hope that helps, and thank you.
Anonymous
  • Posted on Jun 17, 2009
SOURCE: Hobart 250ci quit working
I don't know if it is the same problem that I had. Open up the case where the compressor is and check the air line. If it has come undone the cutter will not do anything. Just reclick the line back on and you should be in business.
Anonymous
  • Posted on Jan 29, 2010
SOURCE: need schematic for hobart airforce 250ci plasma
Found out the model was still under warranty.
Why dont i have any power to my hobart plazma cutter
Maybe blew a fuse . maybe malfuncttion. i would contact company for proper assistance.
Customer Service Hobart Welders
Machine turns on, air compressor runs but will not strike an arc
sounds like the voltage is not getting to the tip. I would suggest taking this in for repair.
Hi I have a hobart airforce 250ci 2 and a half year old lightly used plasma and the power doesn't come on
Check your ground and make sure the ground is clean, if not sand it slightly where it's shinny then try tighten the ground clamp and tighten the ground clamp on the machine itself. Be sure the breaker is not tripped for the machine in the main electrical panel as well check that the electrical cord has not worn down from use, you may have to replace the electrical connector if it is badly worn. you can buy at any hardware store, you will want to buy a 15 amp male connector. If this does not sole your problem please let me now for more help. also be sure air is working for the machine.
1helpful
Hobart airforce 250 ci has power but will not operate
make sure that there is air to the plasma and set at the proper psi. Make sure that the contact tip and nozzle is in the cutting head correct.
My tv will work for like 5 min then it shuts off
Sound like you have a overheating problem. Your capacitors might have reached their end of life thus making them overheat quickly. Try to check if there is a fan inside your TV. If there is a fan, try to clean it see if that helps.
I hope this helps. Have a nice day.
- HotRatchet
1helpful
Hobart 250 has power to unit, but will not run.none of the lights come on.
Sounds like you have more than one problem. Check all fuses. Bringing it to a welder repair shop might be a good idea. Welding suppy houses may be able to help you in your area, and maybe recommend someone.
3answers
Provided Air is between 60 and 80 psi (common operating range).
Power is measured to be in range as per label or manual specs.
Replaced all consummables on the torch head.
Usually the next step is to change the Torch Head. After all else fails this is usually the problem, especially if the torch head became hot while cutting.
2answers
TV goes off intermittently
sounds like an intermittent shut down which is heat related. some part , maybe one stuck on a heatsink is warming up and running too much current triggering shutdown.
to find it you can tell what is shutting down with a voltmeter, or you can heat suspected parts with a blow dryer to speed the shutdown .. or freeze spray to see if it goes beyond your shutdown time.
Monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
Top Hobart Welding Tools Experts
Sean Wright
Sean Wright
oneStan
oneStan
Kardoc
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
