Tag Heuer cj1110.ba0576 Wristwatch Logo
Posted on Aug 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i change teh date on my tag watch with out having to wind it 24 hours to change one day. i need to change 15 days
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Aug 04, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813469
Points
13579
If you pull out crown carefuly, you will notice there are two clicks. The first one is for adjusting calendar (day or/and date). Next one is for moving hands. Pull out to the first click and adjust the date by turning the crown.
Rate me, please.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1672
Points
Tag heuer 2000 profesional series two tone has tag logo on rear of case with swiss since 1860 but has a circle around the the logo? is this a copy as i havent seen this on any other tag.
Setting timex analog mens watch with small window in face of watch indicating day of week, I think
Lots of older watches needed to have the hands advanced 24 hours to advance the date one day. Fortunately most modern watches require the hands to be wound backwards to advance the date, often at the rate of a day per hour. A combination of the backward and forward winding of the hands made adjusting the day and date much simpler and quicker.
A few premium watches had a third position when pulling out the winder, a position dedicated to adjusting the day/date
tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 09, 2010 • Watches
Timex day does not change
see a jeweler and the can fix
Oct 07, 2012 • Watches
I don't know how to set the date properly on my Tag Heuer formula 1 watch. Is there a time of the day that I should do it?
If you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1110.BA0850 , you will see a menu on the right of the screen.
Clcik on "user manual" to download the manual for your watch.
There are no instructions about setting the date apart from saying the date changes at midnight but you can advance the date by winding it past midnight. If you want to advance it more than one day, wind it back and then forward past midnight again. Repeat as many times as required until you reach the date you need.
How far back you need to wind the watch you will have to find by eaperimenting and observing when the date changes. You might hear a soft "click" when winding it backward, you can the wind it forward again.
2helpful
I have a new chronograph Michele watch. How do I change the day of the week without changing the date?
As per the instruction PDF that I just read, the day of the week only changes with each 24 hour rotation. Therefore to change it, you might pull the crown out all the way and wind it through every hour in each day until it advances to the day you want. Then set the correct time. Push the crown in one notch to the second position and wind the dates forward until it stops on the one you want. It doesn't appear that going backwards for either the time (for day of the week) or date works.
3helpful
2answers
I cant adjust the date for my Fossil AM4205..help!
mcdevito75 here, If your Fossil watch has a winding stem it may have 2 positions, gently place a fingernail under the crown and lift as gently as possilble, this should allow you to adjust the date without having to cycle thru the 24 hours to get to the date you want. It may take practise but that first position should be there, Set the date to 1 day before the date you need, then set the watch normally the full 24 hour cycle to get the date you want, this way the watch date will set as suppose to at about mid-night for the next days date.
Aug 28, 2010 • Watches
2helpful
Set day of month
The day is changed when the watch passes midnight or thereabouts. Turn the winder until the date changes and then turn it backwards until it is past the date changing point and wind it forwards.
You will have to experiment to find how far back you need to turn it before going forwards again.
I have an old lucerne windup day date watch but the crown only pulls out 1 notch only to set the time. how do i set the day date or do i have to sit there and advance it manually
The date changes hen the hour hand passes midnight (more or less).
To change the date for more than one day wind it past midnight and when the date has changed, turn the time back past midnight and then forward again.
You may have to experiment to find out how far back before midnight you have to go before going forward again, but at least you don't have to wind it 24 hours for each day!
Feb 16, 2010 • Watches
My calendar has gone two days forward and now it doesnt go back. How do I fix it?
Unfortunately you have to step the mechanism through each day until you reach the correct date.
The date changes at midnight but you can avoid winding it through 24 hours for each day by winding it backward and forward about the midnight hour. How far you have to wind it back you will have to learn by experiment.
10helpful
2answers
Seiko Diamatic Day Date Automatic Watch No: 219050
I have a Seiko Diamatic 780632. To set the day and date, pull the crown once and wind it upwards (away from you) to set the date; winding it downwards (towards you) will set the day. To set the time, you have to pull the crown twice and wind it towards you.
Oct 24, 2007 • Watches
Top Tag Heuer Watches Experts
k24674
Sean Wright
Sean Wright
Ngoro
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
