Unable to connect wifi. keeps coming up fail ?
  • 1,682 Answers
I am assuming you are using a Internet router and you are trying for connect to internet using the Wifi on your mobile or laptop.
I would begin with power cycle the router and try to connect. That should solve 99% of the issues, If that still fails, you can try 'forget the Network connection' or 'SSID' and re-connect
Posted on Dec 10, 2018
2 Suggested Answers
SOURCE:
SOURCE: wifi connection to BT Home Hub problems
Try this link http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=27873&s_cid=con_FURL_gettingsetup/interference#tab4
I had the same problem. I tried everything I could think of but this is what eventually fixed my problem.
Hope it works for you
Posted on Jan 25, 2010
I cannot get my new Kindle to accept my wifi password. It keeps telling me "Kindle is unable to connect".
I has to be connected to the WIFI signal for the password to work and be accepted. Make WIFI is turned on.
Nov 30, 2016 | Tablets & eReaders
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
Netgear wifi router
1) does it lock up completely or will it work hard lined when wifi fails?
2) do all devices wireless fail or just a single device?
3) do you lose connection to the wireless completely or keep the connection but lose access to the internet? (confusing but very different to me)
in the end you could narrow down the problem but if you have already reset to factory defaults and set back up again and again then it may be time to retire that old router.
Dec 28, 2012 | NetGear DG834G Router
Cant conect me DS light to my Wi-Fi
http://www.nintendo.com/consumer/wfc/en_na/ds/wrInitialSetupHelp.jsp
If fail:
Make sure that the wifi settings you have are connect.
See if you are able to connect to another wifi connection.
-Make sure you know the wireless settings for the other wifi connection.
-You may also want to try to connect to an unsecured wifi.
Dec 17, 2012 | Nintendo DS Lite
Unable to connect to wifi it just says scanning
make sure your wifi network is turned on, then open your tablet's wifi and search for it. it should be fine, if not, contact Toshiba for tech help.
Android 4.0 Tablet PC
Feb 04, 2012 | Toshiba Thrive Android Tablet
Cannot load into Gmail
Check your wifi and see if it's well connected or not. I think this is the main problem. Good luck.
Jan 14, 2012 | PANDIGITAL Planet
When trying to access the internet keep getting [conection failed unable to perform operation]
Almost all Nokia N8 user is having a problem with there internet access. Try to do this It will helps. Try to uninstall all the newest application you downloaded from your N8 phone. Now restart your phone. Right after you restart... If your using Wi-fi, go to connection manager in setting, disconnect your wifi connection and recconnect to it again.
May 14, 2011 | Nokia N8 Cell Phone
My wifi internet and also ethernet connection has failed unable to get on to internet
That sounds like your WiFi card has failed. Try installing new drivers before sourcing a new Board.
The part number for searching is; V000121760
They are usually very reliable.
I have spares if you need any.
May 02, 2011 | Toshiba Satellite Pro L300 Notebook
Wi-fi connection problem
There are 2 ways to approach your problem.
  1. Un-protect your wifi connection by removing the password. This is risky since other wifi gadgets can readily connect to your network.
  2. Configure your Samsung phone to connect to your password-protected wifi. Make sure that the wifi protocol of your phone matches that of your wifi router. Example, make sure to set WPA or WPA2 on both device.
May 08, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Open Questions:
Computers & Internet Logo
Alun Cox
