SOURCE: My Vizio 47" (XVT473SV) keeps
Simple test to find out if the problem is internal or external: put a black tape over the IR/remote sensor and see what happens. If the tv still turns on by itself then it's internal and it caused by an aged and unstable power source: the voltage on the 5 volts Stand-by section varies so great that it triggers the start relay - usually caused by aged filtering capacitors.
This is not good, the source can fail at any minute with bad consequences for the rest of the tv. Have the tv inspected and the aged components identified and replaced now, before they fail and fry something else.
SOURCE: vizio xvt473sv sound, but no picture (displays glows)
are you using a cable box? tried to reset first. if still the same problem, at this time you will need to remove the back cover to access the internal part. then look for the screen back light which need replacement.
